Water cooled triple 3080 Build.
So the point was to build a silent 300MH/s rig but since water cooling another system now it’s about the temps.
OS: decided to run windows and not hive.
Case: Fractal Define 7XL
Board: Gigabyte b550 Vision D
Chip: 4650g
Ram: Some cheap 3600mhz 16gb(2x8)
Boot: Some cheap m.2 nvme ssd.
PSU: Supernova 80+ platinum 1200
GPUs: 3 Gigabyte Aorus master 3080
Cooling: 2 420mm radiator with 6 140mm Nactua 2000rpm fans. 3 Alphacool gpu water blocks. Ekwb cpu block. Thermaltake tank/D5 pump combo. Flex tubing with fittings.
Screen: 7” touch mounted to unit.
This is obviously a mining rig. So to explain the why and what, I used the 4650g because it has built in graphics to run the 7” touch screen and will allow the GPUs to mine untouched by the system interaction. Why AMD? Power use simple. This chip will mine full tilt at 7-10 watts. Why this board? I like it. Why the ram choice? It does not matter. Why the ssd choice? Again it does not matter. Why the psu? It matters lol. Why the Arous master gpu? Why not? At these prices you can some bad ass GPUs since they are all the same price.
The reason I chose to water cool? Simple. I water cooled my 2080super and my 2080ti and they went from 100c to 65c with a 1000mhz overclock on the memory. That’s a huge difference in hash rate. Almost 40%. To be clear I have to detune the GPUs on air by 40 to 50 percent to keep them under 100c. On water I can overclock by 10-15 percent above stock limits. It’s huge.
I am putting together a video or two of the process. It’s going to be a long build at least two months long as I am waiting on water blocks from two different makers.
please understand I am not computer literate so please forgive if I get what I am trying to say wrong. I just build shit lol. Other family members make it work.
