Will a nickel CPU block work with a copper radiator?
Solved by Pikatchu,
11 minutes ago, MarvintheParrot said:I know that mixing metals in a custom loop is bad, but will the EK quantum velocity (nickel) work with the Corsair Hydro X 240mm white rad(copper)
https://www.ekwb.com/shop/ek-quantum-velocity-amd-nickel-plexi?___store=default
https://www.corsair.com/us/en/Categories/Products/CORSAIR-White-PC-Build/XR5-White/p/CX-9030007-WW
Thank you for any help!
Majority of the waterblocks are nickel coated with copper based, you should be fine.
Just do not mix Aluminum based blocks/radiator with Copper based ones.
