2 hours ago, boggy77 said:
it will increase the cpu temps as it will make it work harder. but 90 on a 9400f doesn't sound normal. try repasting or replacing the cooler, give the pc a good clean, make sure all the fans work and there is plenty of airflow
I only have 1 extra fan but it comes with the case.
https://linustechtips.com/topic/1318781-cpu-heat/#findComment-14589131
2 hours ago, _DeXTeR_ said:
You are probably on highly bad stock cooler, and you probably have bad airflow PC case.
yeah i have the stock cooler but i think my pc case is ok
its https://www.amazon.fr/gp/product/B07BH23K53/ref=ppx_yo_dt_b_asin_image_o02_s02?ie=UTF8&psc=1
https://linustechtips.com/topic/1318781-cpu-heat/#findComment-14589135
