Sound bar compatible with GPU and Display
Cheers mate for you answer
Let's say that you pined point my fears about the input lag. I should pass for that one and stick a more regular solution.
I made my own research about ATMOS and you right. It's not worth it for small spaces. I could be in a couch but I think I would go with powered monitor speakers or an AVR.
ATMOS is a true feature for high-end equipment apparently. under 400€/$ it does not work as intended.
13 hours ago, Psittac said:Last option would be to get a $200 AVR and a pair of $200 speakers. I love my micca RB42's that I'm using near field *then you could start building a surround setup over time
13 hours ago, Psittac said:bookshelf speakers and an AVR shouldn't add to much difficulty when moving
I think you said it
I will go from here and see and pick up some good stuff
