https://linustechtips.com/topic/1318394-xlr-to-usb-cable/#findComment-14586269
4 hours ago, Daweeedo said:
I'm about to buy a mic with xlr output, and im wondering if a xlr to usb cable would provide the 48v power the mic needs. Im thinking of buying this cable:
https://evenstadmusikk.no/behringer/1110600/behringer-mic-2-usb-microphone-to-usb-interface-cable?ref=prisjakt
if you have a mic that requires 48V phantom power then you need a preamp/interface that can provide this much power.
This audio interface can provide it  + its much cheaper https://www.amazon.de/Focusrite-Scarlett-2i2-Audio-Interface/dp/B07QR73T66
it also has a usb interface wich connects directly to your computer
i would suggest that u also buy an usb extension cable because the included one is quite short
https://linustechtips.com/topic/1318394-xlr-to-usb-cable/#findComment-14586297
The price is in Norwegian Krone which is about 10 Krone to the Euro. So that 177 Krone item is 15 Euros. and that Focusrtie would be over 1000 Krone
https://linustechtips.com/topic/1318394-xlr-to-usb-cable/#findComment-14586325
Please for the love of God do not buy one of those cables. Listen to Ahoy, they are providing good advice.
Sloth's the name, audio gear is the game
I'll do my best to lend a hand to anyone with audio questions, studio gear and value for money are my primary focus.
Click here for my Microphone and Interface guide, tips and recommendations
For advice I rely on The Brains Trust :
@rice guru
- Headphones, Earphones and personal audio for any budget
@Derkoli- High end specialist and allround knowledgeable bloke
https://linustechtips.com/topic/1318394-xlr-to-usb-cable/#findComment-14595269
