16 minutes ago, emotionalpig said:
Are the
Lian Li UNI SL120 58.54 CFM 120 mm Fans 3-Pack
actually good or just nice looking?
It's a decent fan. Not the best out there, but good enough.
CPU: AMD Ryzen 9 - 3900x @ 4.4GHz with a Custom Loop | MBO: ASUS Crosshair VI Extreme | RAM: 4x4GB Apacer 2666MHz overclocked to 3933MHz with OCZ Reaper HPC Heatsinks | GPU: PowerColor Red Devil 6900XT | SSDs: Intel 660P 512GB SSD and Intel 660P 1TB SSD | HDD: 2x WD Black 6TB and Seagate Backup Plus 8TB External Drive | PSU: Corsair RM1000i | Case: Cooler Master C700P Black Edition | Build Log: here
https://linustechtips.com/topic/1318051-case-fans/#findComment-14582958
3 minutes ago, emotionalpig said:
Oh damn I bought them in a hurry cause I was afraid they were gonna sell out since they were on sale. Should I cancel the order?
Like I said, they are good fan, for their price especially. There are better fans out there, like https://www.corsair.com/us/en/Categories/Products/Accessories-|-Parts/ML120-RGB-White-Magnetic-Levitation-Fan-Replacement/p/CW-8960077 but they certainly come at premium. I personally would not spend 40-50 bucks a pop for a fan, but that's just me. If you like these Lian Li fans and they fit your budget, then don't cancel the order.
https://linustechtips.com/topic/1318051-case-fans/#findComment-14582970
well rgb fans dont normally tick the performance box or at lest that's what i can tell. they use the fact that it has rgb to cheap out on it and still sell it at $25-50 each. if you really want performance you need to buy an rgb grill and add it to a performance fan.  imo
https://linustechtips.com/topic/1318051-case-fans/#findComment-14584724
