Hello I Need Some Help I Don't Know What's the Issue Anymore I'm Going Nuts... i try to game and stream to twitch only and no matter what i do my gpu jumps to 100% and Starts Lagging And Spazzing Out. also i have some issues with my screen getting these weird bar's and flash and blink really fast i have done factory resets set everything to default and still having issues I'm only gaming in 1080!! not 4k so idk what the hell is going on... also EVERYTHING IS UP TO DATE
This Is My Build
Intel Core i9-10900K 3.7 GHz 10-Core Processor
Noctua NH-D15 CHROMAX.BLACK 82.52 CFM CPU Cooler
Gigabyte Z490 AORUS MASTER ATX LGA1200 Motherboard
Corsair Vengeance RGB Pro 32 GB (2 x 16 GB) DDR4-4000 CL18 Memory
Samsung 860 Evo 4 TB 2.5" Solid State Drive
Samsung 970 Evo Plus 500 GB M.2-2280 NVME Solid State Drive
New EVGA GeForce RTX 3090 24 GB FTW3 ULTRA GAMING Video Card just got replaced first was faulty
Lian Li Lancool II Mesh ATX Mid Tower Case
EVGA G5 1000 W 80+ Gold Certified Fully Modular ATX Power Supply
2x ASUS TUF Gaming VG-9QM First Set To 240hz Second Set To 60hz
internet speeds are 200Down 20up
https://linustechtips.com/topic/1317581-help/
Your post belongs in the graphics cards or troubleshooting subforum, a mod will probably move it. Edit: Oh you just double-posted it, great. 🙄
Please try to make your thread title something that is descriptive of the actual problem. Every day multiple people post threads with titles that are just variations of "I need help."
"Spazzing out" does not describe your problem.
Post a picture of the artifacts on the screen.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
https://linustechtips.com/topic/1317581-help/#findComment-14579486
1 hour ago, somer4ndo said:
That sounds like what happened to the first 2080ti(iirc), that were literally dead on arrival, but anyway, have you DDUd your system/reinstalled windows after this started happening?
fresh install of windows and everything that i could update i did.
https://linustechtips.com/topic/1317581-help/#findComment-14579584
Hmmm, I'd still try DDUing and reinstalling the drivers to see if maybe something wrong happened along the way before either waiting for more experienced people in the troubleshooting subforum check this out or contact EVGA again. If you want people to take this post seriously, I'd consider changing the tittle to something like "3090 problems - it keeps saying it's at 100% and stuttering display with light gaming/streaming" for example. And what did you use to say where GPU usage is at? Afterburner?
https://linustechtips.com/topic/1317581-help/#findComment-14579597
evga percision x1
https://linustechtips.com/topic/1317581-help/#findComment-14579608
> Moved to Troubleshooting.
https://linustechtips.com/topic/1317581-help/#findComment-14579852
