Hi, i have been getting around only 30 FPS at ultra settings 1280X1024 resolution on Battlefield 1. Checked it and i assume that i'm having CPU bottleneck, GPU usage was low.
Specs:
CPU: Intel Xeon X5450 3.00 GHz Stock
MB: Asus ROG Commando
GPU: Sapphire R9 280X Tri-X OC 3GB GDDR5 384-Bit (Undervolted and Underclocked)
RAM: Kingston 6GB DDR2 800MHz CL6
HDD: Samsung HD155UI 1.5 TB 5400 RPM
PSU: Gigabyte P650B 650W 80+ Bronze
OS: Windows 10 Pro 64-Bit 20H2
Here's the screenshot:
Specs:
it could be. but every cpu bottlenecks every gpu. but this sounds like bad bottlenecking.  does turning down the settings help?
my signiture was cool, but its a lie now
the xeon is a server cpu with many cores, but those cores run at really low clock speeds, and old games cant utilize that many cores so the 2-3 cores being used arent enough
Edited by yeetus the mighty
wrong info
when you have a cpu bottleneck the way to put more load on the gpu is to make it work harder ... crank up the details and other graphical setting, change the resolution for something higher ... etc.  It won't give you more fps but it might put some load % on the gpu while getting you better graphics ... cpu bottleneck won't disappear thought.
you can try to lower the cpu work but it's kind of hard to do if there's no options to lower things like the amount of npc present and such.
you can also try to see if there's a lot of things running in the background ... close as much as possible and that might free some resources for your game to use ...
as said previously by the others ... there's no miracles to be made here ... that cpu is not a power house for gaming ... maybe it was good back in the days but now it's time to retire it or turn it into a media pc or office desktop ... or something like that.
I9 10850K
EVGA RTX 3080 TI FTW3 ULTRA
32 Gb Crucial Balistix ddr4 3600mHz 16-18-18-38
MSI Z490 Tomahawk
Fractal Design Ion+ 860W platinum
Arctic Liquid Freezer II, 360mm
WB Black SN750 NVMe ssd
TeamGroup L5 3D Lite 1 Tb sata SSD
