Hello, I need help building a NAS. The price needs to be under $600 CAD and ran by AMD. It can either be a NAS unit or NAS computer (if that makes any sense).
The case needs to hold 8 Hard drives and have 2 5.25 slots.
The motherboard needs to have room for 2 Rivo PCIe SATA Card, 8 Port with 8 SATA Cable, SATA Controller Expansion Card and needs to support RAID.
If you have PC part Picker links for canada then send them my way.
Edit, i have a low powered GPU for it already!
Intel Computer - Intel i5 4460, MSI H81MP33, 8 GB DDR3, AMD R9 200 3 GB, Kingston A400 120 GB 2.5″ Solid State drives, Cooler master N200 microAFX, 500w.
AMD Computer - AMD Ryzen 5 2600 3.4 GHz 6-Core Processor, Cooler Master Hyper TX3 Evo 43.1 CFM CPU Cooler, ASRock B450M PRO4 Micro ATX AM4 Motherboard, G.Skill Aegis 16 GB (2 x 8 GB) DDR4-3000 Memory, Zotac Gtx 1060 6gb, 2x Kingston A400 120 GB 2.5″ Solid State drives, 1tb WD and a 2tb Seagate hard drives, Thermaltake Versa H18 MicroATX Mini Tower Case, and an Corsair CXM 550 W 80+ Bronze Certified Semi-modular ATX Power Suppler.
MacBook Pro - 2.5GHz Intel Core i7-4870HQ (Turbo up to 3.7GHz), Logic Board 2.2ghz 6gb 661-02524, 16GB 1600MHz DDR3L (non-upgradeable) , Intel Iris Pro 5200 (integrated), AMD Radeon R9 M370X with 2GB GDDR5, and an 512GB solid-state drive.
TerraMaster F2-220 - Intel Dual Core 2.41GHz, Terra Master NAS Board, 2GB RAM DDR3 SDRAM, and two 3TB IronWolf NAS hard drives.
https://linustechtips.com/topic/1316534-need-help-building-a-nas/
Is there a reason why you need amd here, intel is often the better choice due to the igpu is included.
Why those cards. Id use onboard sata if you can, esp for that coast, otherwise, go LSI/broadcom
What os do you plan to use? id use software raid here.
What newtwork speed? How many TB do you need? Does $600 include drives?
I do currently have a GPU already ready for it. I should include it in the post
The main onboard sata will be for the main drives and used for docker, plex and storing my camera files for editing.
I was thinking freenas or something, but if you have any ideas send them my way!
Currently its only 1gb/second, at least 6TB right now but will be adding more and the drives don't include the $600.
How many drives are you planning on adding? Id probalby do only 4 bays and do something like 4x14TB HDDs.
Im a fan of proxmox, and create vms for different services, and you can use all the same ZFS features.
Do you have any other parts already?
6-8
proxmax i will look them up.
Just the GPU, and a CPU fan cooler.
