Vram chip replacement
Askejm
Hi. I recently broke my GPU (probably from static electricity) and is getting some pretty heavy vram artifacts. We tried sending it to a repair center and they said they couldn't fix it. Is it hard to swap vram? My aunt works with chip stuff and has all the soldering tools required at her job. My GPU is a 2080 super, using Samsung K4Z80325BC-HC16. How hard is it to swap vram? Can one of you maybe guide me through a simple explanation of what happens? And do you think my aunt could do that? She said her soldering skills was a single level below what you need to have to be qualified to solder for NASA.
Thanks
It’s possible. But takes a special type of specialist. A hot air station will be needed, not a soldering iron.
look up reballing BGA chips to get an idea of what it takes.
Does your aunt have a BGA rework station, and are you able to get identical VRAM chips to the ones that are broken?
VRAM chips are not like resistors or DIP packages - they have little balls of solder on each pin that goes into the PCB, then the PCB is put into an oven and the solder melts, mounting the VRAM to the PCB.
elephants
alright but when I order them new, won't they already come with those ball things?
First, does she have a BGA rework station?
She'll need that to be able to remove the existing VRAM chips without damaging the PCB.
elephants
Some chips do, some have to be balled
I can ask her
I think it's the same? Let me send you a picture I took
Oh alright, do you know if K4Z80325BC-HC16 is balled?
I asked her and she said she thinks it'll be hard cuz it's a SMD chip meaning it'll be hard for her to apply the paste
Just now, Electronics Wizardy said:
How do you know the vram is bad? And how do you know its that chip that is bad?
In these cases is notmrally cheaper to just get a new gpu.
I'm not 100% sure, but 3 of my friends said it looks like vram artifacts. I'm not completely sure as I don't have the tools to check however. I was trying to a kraken x73 to it with the g12. It probably happend when me and my dad tried to get a stuck standoff out, I'll admit we may not have been the nicest to it in terms of protection against static electricity
Can a gpu damage the pc if this is done incorrectly? She is expressing concern for it. She isn't the most knowledgeable in computer electronics
And no way I'm getting a 2080 super in this chip shortage. I paid $1000 outside of it and can't afford a new one just like that
Lol she has no idea what she is doing. I guarantee she is not capable of properly reballing and resoldering several VRAM chips, assuming that is even the problem.
Just get a new GPU. This one is a lost cause.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
Potentially not, but she has some very skillful colleagues
BUt do they want to do this for free? This is normally work that is billed in the hundreds a hour, and you want someone that knows how to fix gpus and other computer parts, not just general electronics repair.
I think you are severely underestimating the skill required to do several successful VRAM chip reballs. I guarantee none of them will even attempt it for less than a hundred bucks.
SPECS:
Even assuming she knows how to do this job..which I'm rather doubtful unless you happen to have an aunt that works in a $$$ pcb rework office, you're planning on blindly replacing $16 a pop memory chips?  I'm also getting the instinct that doing this job on vram chips is another level of care needed vs. "hot air the shit out of it and tweezer it off" that you can do with other types of BGA parts.
Have you run OCCT memory test to even see if it reports problems?  DId someone knock a capacitor off with rough handling?  Because static electricity killing finished parts seems pretty rare.  I've put tons of gpu's down on carpet and generally not been ESD safe handling them without problems...ever.
This guy seems to have been successful with it but who knows the reliability of it and whether he didn't just get lucky:
Workstation:  14700nonK || Asus Z790 ProArt Creator || MSI Gaming Trio 4090 Shunt || Crucial Pro Overclocking 32GB @ 5600 || Corsair AX1600i@240V || whole-house loop.
LANRig/GuestGamingBox: 13700K @ Stock || MSI Z690 DDR4 || ASUS TUF 3090 650W shunt || Corsair SF600 || CPU+GPU watercooled 280 rad pull only || whole-house loop.
Server Router (Untangle): 13600k @ Stock || ASRock Z690 ITX || All 10Gbe || 2x8GB 3200 || PicoPSU 150W 24pin + AX1200i on CPU|| whole-house loop
Server Compute/Storage: 10850K @ 5.1Ghz || Gigabyte Z490 Ultra || EVGA FTW3 3090 1000W || LSI 9280i-24 port || 4TB Samsung 860 Evo, 5x10TB Seagate Enterprise Raid 6, 4x8TB Seagate Archive Backup ||  whole-house loop.
Laptop: HP Elitebook 840 G8 (Intel 1185G7) + 3060 RTX Thunderbolt Dock, Razer Blade Stealth 13" 2017 (Intel 8550U)
Hmmmm alright
Yeah she is pretty good friends with them and last time my 1050 ti her colleague said he could do it then they found out there was some code on the broken part they don't have
I doubt I knocked a capacitor off or smth, but I can check when I get it back. And how do I do an OCCT memory test, and where does it report the problems?
No idea how reliable this test actually is though but it's free to try.
Interesting note that it's the same artifacts repeating across 4 columns of the screen.  I may be over-analyzing it:
Alright I'll try that
I was unable to start the test cuz the screen was stuck at 800x600 so the ui was too big to click the button.
I examined the board thoroughly and took pictures of these areas. Do they look broken to you?
_MG_9112.thumb.jpg.e045a1c07d5a01ba0b3336b1747384bd.jpg_MG_9111.thumb.jpg.53fec829edc946e513ef581dd61cfccf.jpg
