I have a msi x570 A pro Motherboard, and a case from enermax. The 5 fans are controlled (or rather not controled) with the molex connector. So they always run on 100%. To get control, i got told to buy a 3 pin to molex adapter to plug into the mainbaord (as far as i know the shouldn't be a problem connecting a 3 pin connector to a 4 pin header). The fans draw "DC 12V (0,13A) / 5V (0,68A)" and i was wondering, if i would be able to connect all 5 of my fans to one port?
Thx for y'alls help
https://linustechtips.com/topic/1314876-molex-fan-maiboard-control/
Thx for y'alls help
https://www.amazon.ca/2-Pack-Pin-Molex-Splitter-Cable/dp/B07F354TP3/ref=sr_1_6?dchild=1&keywords=molex+to+pwm&qid=1615649999&sr=8-6
ya i would do like 2-3 fans per hesder
