Overclocking RTX 3070 question
22 minutes ago, EduarDoc said:Hello all,
I am new at this stuff of the overclocking. I am just a casual gamer but I find the 'thinkering' with voltages and frequencies interesting. I have been trying to overclock my GTX370 using afterburner but I feel like I reached a limit in this process. Everywhere I have researched increasing the power limit is important but my slider only goes to 100% and I have checked all the boxes in the settings.
I feel comfortable that I would be able to increase the limit comfortably because running Superposition benchmark I am hitting a comfortable max temp of 61C. With this settings I have been able to push the memory clock +900MHz and the corresponding Core Clock. When compared to others in the leader board it seems that I am reaching the memory frequencies limits but way below the average temps.
Does anybody know how can I 'unlock' the power limit? Did I hit the bad silicon lottery? Am I flying to close to the sun?
Thank you!
By GTX370, I assume you mean RTX 3070 right
For some models, like the MSI Ventus models, you can't increase the power limit above 100%, as it's hard limited in the BIOS. You could get around this by flashing a different BIOS.
