I went to a video on youtube and found "The Best 700$ Gaming/Streaming PC". Only things I changed were the case, the amount of ram (brand still the same), and I had to pick the graphics card myself. See what you think.
Budget (including currency): 2,000 AUD
Country: Australia
Games, programs or workloads that it will be used for: Minecraft, Fortnite, Rocket League, etc.
Other details: I have a existing parts list. Tell me if I should change something.
https://linustechtips.com/topic/1314530-rate-my-build-plan/
I would question why 32 GB, but first I must question why 2 sets of 16GB. Scratch one kit and get the 5700XT. Otherwise solidly overbuilt PC for the games you play....Just the way I like it. What about the monitor?
Whorsair: 5900X | MSI RTX 3080 Gaming X Trio | Asus X570-F | Corsair H115i Platinum | Corsair Vengeance 32GB CL14 | Corsair QL 140 | Corsair HX850 | Corsair Carbide Air 540 | Corsair  Corsair K95 | Corsair Dark Core Pro | Corsair MM800
https://linustechtips.com/topic/1314530-rate-my-build-plan/#findComment-14554439
I would take 16gb of good 3200MHZ RAM
double rank modules, so you gain the same 4 slot amd advantage
hdd 7200rpm, no compromize on this please
to be honest, doesn't seems to be an overall weighted starting point... for a 2000 budget I agree with the other guys, you have to expect more an better
https://linustechtips.com/topic/1314530-rate-my-build-plan/#findComment-14554508
