How bottlenecked will an RTX 3090 with i7 8700K be?
GifCo
Wondering how long I can hold out updating my CPU, assuming I can ever get my hands on a 3090!
In 1080p there will be a very minor bottleneck, although a decent OC would help. In 1440 and 4K there shouldn’t really be a bottleneck. The 8700k still holds up extremely well in 2021
although a 3090 is pretty crap value, not sure if it’s really worth it over the 3080
geometry is hard
b550 > x570
What games do you play, and at what resolution? Probably very little to no bottleneck. The 8700K is still a very solid CPU.
Main PC:
AMD Ryzen 7 5800X • Noctua NH-D15 • MSI MAG B550 Tomahawk • 2x8GB G.skill Trident Z Neo 3600MHz CL16 • MSI VENTUS 3X GeForce RTX 3070 OC • Samsung 970 Evo 1TB • Samsung 860 Evo 1TB • Cosair iCUE 465X RGB • Corsair RMx 750W (White)
Peripherals/Other:
ASUS VG27AQ • G PRO K/DA • G502 Hero K/DA • G733 K/DA • G840 K/DA • Oculus Quest 2 • Nintendo Switch (Rev. 2)
Laptop (Dell XPS 13):
Intel Core i7-1195G7 • Intel Iris Xe Graphics • 16GB LPDDR4x 4267MHz • 512GB M.2 PCIe NVMe SSD • 13.4" OLED 3.5K InfinityEdge Display (3456x2160, 400nit, touch).
Got any questions about my system or peripherals? Feel free to tag me (@bellabichon) and I'll be happy to give you my two cents.
PSA: Posting a PCPartPicker list with no explanation isn't helpful for first-time builders :)
why on earth get a 3090?  If you have concerns about updating a CPU, you can barely afford the 3090.   3080 max.
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
this is for a 3080 so just add 5-10% to the numbers for a 3090
assuming you are playing at 1440p and the 8700k oc'd  between a 3900x and 9900k, best guess is 10% and around 5% at 4k. It won't be as bad as the 3600.
The differences are mostly only in AAA or competitive titles.
honestly if there are any bottlenecks that's alot of money given the price diff between a 3080 and 3090, best if you can get a 5800x since it's in stock atm, or just make sure the 8700k is oc'd in a 4x8gb config to minimize the losses.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
Not bad, but I’m telling you right now that getting a 5900x + 3080 would be more worth it than just a 3090
3080 doesnt have enough VRAM to be a good long term investment for 3D rendering, also not worth considering with almost certain 380TI incoming. And yes I can barely afford the 3090 hence not waning to upgrade my CPU and in turn MOBO at the same time.
Nice, Im running ultra wide 1440 so should be good for a while then, and this is half for Rendering as well as gaming so the extra VRAM on the 3090 is a better long term investment i thik..
Disagree about the VRAM part. Games today barley use more than 8GB at 1440p so trust me, you do NOT need a 3090. A 5900x + 3080 is a better investment. You are losing 10% of performance compared to the 3090, but with the 5900x you are getting double the cores and threads, and in some AAA games the extra CPU horsepower with give you better performance with an 5900x + 3080 compared to the 8700K + 3090
geometry is hard
b550 > x570
It depends on a few factors, what sort of games, resolution, expected frame rate ETC.
So if you are playing current Triple A games like Cyberpunk, that game will use all your CPUs power it has and might be a small bottleneck. Older games should be fine just few of the bleeding edge modern games.
Resolution, if you are playing 4k aiming for 60hz it should be fine, 1440p 144hz should be ok but pushing to the edge, 1440p 240hz you might see a bottle neck depending on the game and same with 1080p high refresh.
Overall it should be ok for now but you might want to look at a upgrade to a 8 or 12 core chip in a year or two. Personally i’d get a 12 core because it would just last longer and the price difference isn’t that much
Yea I agree but the VRAM isn't for games it's for 3D renders and the 3080 even today is a bit on the low side and in 3-4 years will be a limiting factor.
I always usually buy top tier cards I'm running a 980TI I got when they released and it's only now starting to slow me down.
