Ethernet cable cat 5e is what ya need /or 6A as @fuzz0rmentioned
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
https://linustechtips.com/topic/1313945-lan-cables/#findComment-14549189
4 minutes ago, Smegmantas said:
I need a LAN cable to hook up to my pc? What do I get? What are the router to pc connection  cables called?
Typically they are called "ethernet cables". They have two RJ-45 connectors on either side and come in different categories.
Most like you'll run into CAT5E, CAT6, CAT6A or CAT7.
The difference between these cable standard is the speed they can achieve over a certain length.
Do you for example need 10 gigabit? (If you don't know, you likely don't, because 10Gb equipment is so expensive, most people won't have it now).
What length of cable do you need? Will the cable be run inside or outside? Through a wall next to electricity?
https://linustechtips.com/topic/1313945-lan-cables/#findComment-14549192
