Pc boots but no signal from anything
Solved by TrigrH,
1 minute ago, eggnogeggs said:Also, tried putting the motherboard on the box and trying it, still getting error message. Might send it to manufacturer to get it repaired or replaced if you can do that, ( I'm not sure because I've never done It before.)
You can, if its under warranty, otherwise time for a new motherboard sadly.
rikitikitavi ·
Posted in Laptops and Pre-Built Systems0 -
Vibin ·
Posted in Troubleshooting0 -
1
GreenLeaf ·
Posted in Graphics Cards2 -
1
paulyron ·
Posted in Programs, Apps and Websites1 -
Gecko ·
Posted in LTTStore.com Merch0
