Hi everyone,
I really hope someone here can help me. I have recently added a Gigabyte RTX 3070 Vision OC to my system:
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor
CPU Cooler: Corsair iCUE H150i RGB PRO XT 75 CFM Liquid CPU Cooler
Motherboard: Asus TUF GAMING B550M-PLUS Micro ATX AM4 Motherboard
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3600 CL18 Memory
Storage: Western Digital Blue SN550 1 TB M.2-2280 NVME Solid State Drive
Storage: Samsung 870 QVO 2 TB 2.5" Solid State Drive
Storage: Western Digital Blue 2 TB 3.5" 5400RPM Internal Hard Drive
Video Card: Gigabyte GeForce RTX 3070 8 GB Vision OC Video Card
Case: Lian Li PC-O11 Dynamic ATX Full Tower Case
Power Supply: Corsair RMx White (2018) 750 W 80+ Gold Certified Fully Modular ATX Power Supply
I've started gaming with it and the performance has been all over the place. Sometimes it is fine, but sometimes I get massive frame rate drops and inconsistent frame rates.
I have attached a log file monitoring hardware info from a session in Battlefield 1. I was playing at 1440p with settings on High.
I would really appreciate it if someone could take a look at these values and see if they can see where the issue might be.
'BF1 Log.xlsx' is colour coded. Green indicates good in-game performance, red indicates poor of fluctuating in-game performance, blue indicated as-expected cinematic performance and orange indicates poor cinematic performance. I have split the logs into selected CPU, GPU and Other metics.
As you can see in the log files, frame rates drop as low as 7 FPS and when they recover from there jump around massively.
Everything in the GPU metrics drops off a cliff, including power input. I also found it interesting to note the performance limit indicators, shown below:
Framerate [FPS] Performance Limit - Power [Yes/No] Performance Limit - Thermal [Yes/No] Performance Limit - Reliability Voltage [Yes/No] Performance Limit - Max Operating Voltage [Yes/No] Performance Limit - Utilization [Yes/No]
RTSS GPU [#0]: NVIDIA GeForce RTX 3070:  GPU [#0]: NVIDIA GeForce RTX 3070:  GPU [#0]: NVIDIA GeForce RTX 3070:  GPU [#0]: NVIDIA GeForce RTX 3070:  GPU [#0]: NVIDIA GeForce RTX 3070:
144 No No Yes Yes No
144 No No No No Yes
72 No No Yes No No
52 No No No No Yes
68 No No No No Yes
71 No No No No Yes
70 No No No No Yes
71 No No No No Yes
72 No No No No Yes
72 No No No No Yes
72 No No No No Yes
3 No No No No Yes
7 No No No No Yes
7 No No No No Yes
19 No No No No Yes
15 No No No No Yes
7 No No No No Yes
8 No No No No Yes
23 No No No No Yes
127 No No Yes No No
143 No No Yes No No
126 No No Yes No No
144 No No Yes No No
142 No No Yes No No
104 No No Yes No No
129 No No Yes No No
140 No No Yes No No
144 No No Yes No No
144 No No Yes No No
Please can someone suggest what the issue(s) might be?
Thank you!
BF1 Log.xlsx
https://linustechtips.com/topic/1313772-rtx-3070-massive-frame-drops/
1 minute ago, Nocmj1 said:
Had an EVGA RTX 2060 XC Ultra - only just found out what DDU is!
Would you recommend I do that and reinstall fresh drivers?
Yes, for sure. Maybe you even need to reinstall windows fresh,but try DDU first,  follow the instructions especially for using safe mode.
-Scott Manley, 2021
