Will my 80+ Gold PSU from 2020 need a pure sine wave UPS V.S. a simulated sine wave one?
Solved by Guest,
23 minutes ago, FluorescentGreen5 said:My PC draws around 450 W in an absolute worst case scenario, however, that value could break 500 when I consider overclocking (I'm using a Ryzen 5 3600). I'd say 5 minutes is plenty to save my work or hibernate my system and I don't plan on actually using my system on battery. Since I live in Australia, my options for UPSes are kinda limited and finding any 600 W UPS for under 200 AUD is a pain let alone a pure sine wave one.
You don't need pure sine wave.
Only super cheap PSUs with antiquated technology shut down when not on a pure sine wave.
