This website says Load Power Consumption in Crysis 3 for 780 ti is 556w!!! Does that mean I need a bigger PSU than 750w if I decide to buy it!?
Enthoo Primo - ASUS Maximus Formula VII - 4790k 4.8ghz 1.28v - EK Supremacy Evo Clean - 16GB Crucial Ballistix Tactical - 1000w EVGA Supernova Gold - 2x Alphacool Monsta Rads in push/pull - 2x Galaxy 780 HoF with EK waterblock
Build Log http://imgur.com/a/UV6Wh Just want to warn everyone, my build log is pretty mediocre.
https://linustechtips.com/topic/131303-780-ti-load-power-consumption/
No, that is total system power. Even then it won't be that much.
Well that website is wrong. That is most likely the power draw for the entire system. No, you don't need bigger than 750W. WHY DO PEOPLE MAKE THIS MISTAKE ALL THE TIME! You'd be fine with a 550W PSU.
EDIT: Sorry for the little rage back there, I've just been here a while and I'd be fairly wealthy if I got £5 for every person who thought they needed double the necessary Wattage to power their builds.
CPU: 5930K @ 4.5GHz | GPU: Zotac GTX 980Ti AMP! Extreme edition @ 1503MHz/7400MHz | RAM: 16GB Corsair Dom Plat @ 2667MHz CAS 13 | Motherboard: Asus X99 Sabertooth | Boot Drive: 400GB Intel 750 Series NVMe SSD | PSU: Corsair HX1000i | Monitor: Dell U2713HM 1440p monitor
OH!!! Okay thank you all! Glad this forum exists, with fast responses
To add to what others have already said:
Psu calculators for the most part are highly inaccurate. It's good to look up kill-a-watt measurements as well from similar systems to compare results.
