Hi, i have a question about My motherboard with fan ports. Running a gigabyte a520m ds3h. I have two fan headers and the CPU fan header och My stock and cooler is on. wandering IF it is possible to fit 6 fans in it without a fanhub. Just using splitters. Have No manual so i need to know how much amp One port can handle. IF this works i going to runt two 140mm and 4 120mm fans
https://linustechtips.com/topic/1312123-question-about-fans/
Typically they are rate to one amp each. Three normal fans are totally fine on one header. You can also look at the current draw your desired fans are rated for and do the math. Remember, however, that the rating is at max RPM, which they will typically not be running at.
Be sure to QUOTE or TAG me in your reply so I see it!
CPU Ryzen 7 5800X3D GPU EVGA 3080 Ti FTW3 Ultra MOBO Asus ROG Strix B550-F Gaming RAM Crucial Ballistix 3600 MHz CL16 32 GB PSU Corsair RM1000x COOLING Noctua NH-D15
https://linustechtips.com/topic/1312123-question-about-fans/#findComment-14534524
