Hi guys,
having not logged into my home server for a few days or even needing to access any shares, last night I sat down to watch a movie but after navigating to the share on my Windows PC, explorer allowed me to get one folder deep and then promptly hung. A server reboot didn't solve the problem.
I then tried to access all of my web consoles (OMV Admin / OMV Cockpit / Portainer / Pi-Hole......) and none of them responded.
These services (or at least Pi-Hole) were clearly working as it should since I still had full internet connectivity. I don't have a secondary DNS address specified on my clients by default so when the server falls over I loose the internet.
I could ssh into the system without issue but a soon as I tried to run any command more complex than ls (or something similar) it appeared to crash. Finally I tried running omv-firstaid but all I was presented with was half a screen showing the 1st couple of repair options and the rest black. ctlr+c didn't respond. apt-update / upgrade would also appear to stop after a few seconds and again ctlr+c didn't appear to do anything.
Opening another terminal window showed the system was still up and running but as soon as I tried another command that session crashed.
This morning I can confirm that running these commands locally work without issue but now after a full OMV reinstall I am still unable to access the web console.
I can confirm the server is connected to my network as it is showing on my router's 'connected devices' list with the IP address I specified however, when I log into the server it tells me that I should log into the web console with a different IP address (this address is valid on my network as I have a small pool reserved for DHCP clients usable by visitors) but clearly assigned by DHCP rather than the static one I specified.
*UPDATE* just this very minute I have tried sshing into the server with the static IP I specified and now its moaning about 'WARNING: REMOTE HOST HAS CHANGED' and letting me know its possible that someone is doing something nasty but also possible the host key might have changed.
 Any help would be greatly appreciated.
P.S. I'm a Linux noob so go easy.
Living Room PC - Lian-Li O11 XL Evo - MSI X870 Tomahawk Mobo - AMD 9800X3D - 32GB DDR5 Ram - RTX 4090 - 2TB Samsung 990Pro NVMe - Antec 1200w PSU - Dual Custom Loop Cooling - GPU cooled with EK Quantum Surface S240 + EK Quantum Surface P360M X-Flow Rads - CPU cooled with EK Quantum Surface X360M Rad
Bedroom PC - Hyte Y60 - Intel Core i5 13600k - MSI Pro-A Wifi Z790 Mobo DDR5 - 32GB Ram - RTX 5070ti - 1TB Samsung 990Pro NVMe - Corsair HX1200i PSU - CPU + GPU cooled with Hyte Y60 Corner Distro Plate - EK Coolstream S120 + EK Quantum Surface S360 + EK Quantum Surface X240M
Extension PC - Lian Li o11 Dynamic - Intel Core i9 9900k - MSI Meg Ace Z390 Mobo - 16GB Ram - RTX 3080ti - 256GB Samsung NVMe - Corsair AX850 PSU - CPU + GPU cooled with dual EKWB 360 Rads + G1 side EKWB distro plate.
Office PC - Thermaltake Tower 100 - Intel Core i7 8086K - Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - iGPU - 256GB Samsung NVMe - EVGA B5 850W PSU - CPU cooled with dual EK Quantum Surface P120M Rads + Barrow 3-in-1 Block, Res & Pump.
Spare - Corsair 250D - Intel Core i7 8700k - Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - GTX 980ti - 256GB Samsung NVMe - BeQuiet P11 750 PSU - CPU cooled with EK Coolstream S240 + S120 Rads + EK Pump / Res Combo
Annex - Corsair 280X - Intel Core i7 4790k - Asrock H97M ITX Mobo  - 16GB Ram - EVGA GTX 1080ti - Corsair SFXL600 PSU - CPU + GPU cooled with triple EK Coolstream S240s + EK Pump / Res Combo
NAS PC - Fractal Node 804 - Intel Core i7 3770k - Asus P8Z77-M Mobo - 16GB Ram - MSI GTX 1660 Ventus - Corsair AX850 PSU - Unraid 21TB Storage Server
Living Room AV Setup 5.1.4 - Nvidia Shield - Yamaha RX-A6A - 2 x B&W CM9s2 - 2 x Monitor Audio FX Silvers - 4 x B&W CCM665s - B&W CMCs2 - SVS SB13 Ultra - LG OLED65C1
Extension AV Setup - Sonos ARC + Sub (Gen 3) - LG OLED65C6V + Sonos Amp - 5 x Monitor Audio C265s
Bedroom AV Setup - Yamaha WXC-50 - 2 x B&W CM1s - Rel Quake - LG OLED42C2.
https://linustechtips.com/topic/1312004-omv-issues/
This is normal. Your SSH key has changed since your previous OMV install on the same IP-address. SSH is designed to not accept that without warning the user as the server might've been compromised. You can safely ignore this.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
https://linustechtips.com/topic/1312004-omv-issues/#findComment-14533178
How old was the SD card you used?
https://linustechtips.com/topic/1312004-omv-issues/#findComment-14533180
Cheers, thought as much. I don't have the option to ignore so should I just delete the known hosts file on my windows pcs or add the suggested key to the file to sort?
https://linustechtips.com/topic/1312004-omv-issues/#findComment-14533257
What SD card?
https://linustechtips.com/topic/1312004-omv-issues/#findComment-14533261
Just now, ChrisLoudon said:
What SD card?
Oops my bad, I thought this was on RPI. I personally dont like OMV due to how resource heavy and troublesome it gets. I also had network related issues after installing OMV and fixing it was a total pain in the butt and required patching netplan.io manually.
yeah, you can delete known host to get rid of that error.
https://linustechtips.com/topic/1312004-omv-issues/#findComment-14533265
lol, no worries. Kinda thought that's what you were getting at.
I don't like being beaten with these things so I'm gonna persevere a bit more with OMV before trying something else.
https://linustechtips.com/topic/1312004-omv-issues/#findComment-14533305
Well, I dunno what's happened but its back up now.
Changed my web control panel port to 81 and now its working. Not sure why it now decided to work as I did this yesterday and this morning and it wouldnt work
https://linustechtips.com/topic/1312004-omv-issues/#findComment-14533324
What type of drive did you install OMV on? I had experienced very similar behaviour at a time when the server was having issues reading the boot disk/USB.
Quote
This is normal. You reinstalled the OS so the host-key changed but your SSH client doesn't know that so it warns you that something's fishy about the server.
On Linux it should tell you in that warning the exact command to run to remove the server from the list of known hosts. This will make the error go away when you re-add it.
https://linustechtips.com/topic/1312004-omv-issues/#findComment-14533326
Spoke to soon.
Died again.
Managed to get into the web console to do a few updates but after a reboot, its back to square 1
https://linustechtips.com/topic/1312004-omv-issues/#findComment-14533370
