So I just recently got a 2080 super from microcenter STRIX model, and for some reason when I plugged it in I get display and it loads up everything but none of the fans come on. And I know that they idle at 0 till 55 c. But they won’t even turn on. The two red lights next to the power cables coming from the PSU are red. So I thought maybe new power supply? Tried it, same thing. Someone help please. Picture of the lights below. THANK YOU!
https://linustechtips.com/topic/1311916-someone-help/
What happens when you play games/run benchmarks? Do fans spin then? Is the performance as expected? Are your temps as expected? Missing some crucial info here
Main Rig: R9 5950X @ PBO, RTX 3090, 64 GB DDR4 3666, InWin 101, Full Hardline Watercooling
Server: R7 1700X @ 4.0 GHz, GTX 1080 Ti, 32GB DDR4 3000, Cooler Master NR200P, Full Soft Watercooling
LAN Rig: R5 3600X @ PBO, RTX 2070, 32 GB DDR4 3200, Dan Case A4-SFV V4, 120mm AIO for the CPU
HTPC: i7-7700K @ 4.6 GHz, GTX 1050 Ti, 16 GB DDR4 3200, AliExpress K39, IS-47K Cooler
Router: R3 2200G @ stock, 4GB DDR4 2400, what are cases, stock cooler
I don't have a problem...
https://linustechtips.com/topic/1311916-someone-help/#findComment-14532638
Sorry I was in a panic when I posted this, but the fans don’t come on under load. Temps excel 80 c. Because the fans don’t turn on.
https://linustechtips.com/topic/1311916-someone-help/#findComment-14533695
8 hours ago, The_russian said:
IIRC those lights indicate if there is power draw from the respective cable, so they should be on. Have you actually put a load on the card and watched the temps to see if they would go over 55C without the fans turning on?
Yes I did put a load on the card and the fans still don’t turn on and highest I’ve seen temps was 88 degrees Celsius. I’ve built about 15 computers and never had this issue and it’s got me stumped.
https://linustechtips.com/topic/1311916-someone-help/#findComment-14533710
The lights should be white, not red.
OP, exactly how long ago did you buy this card?  I haven't heard of Micro Center having any 20-series cards for months, they're all out of production except now Nvidia is bringing the 2060 back to try to ameliorate/take advantage of shortages.
Also, for future reference, it's good to make your thread title something that's actually descriptive of the issue, there's like 20 threads per day on the LTT forums that are just titled some variation of "help me."
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
https://linustechtips.com/topic/1311916-someone-help/#findComment-14533716
8 hours ago, Benito593 said:
It looks like you are using two PCIe cables, correct? If you aren't, try using two separate cables. Is it 1 cable with 2 x 6+2 pins?
I’ve tried two separate cables. Different plugs for the PCIe cables. Nothing seems to work, starting to think it’s faulty.
https://linustechtips.com/topic/1311916-someone-help/#findComment-14533718
Also, for future reference, it helps to make your thread title something that's actually descriptive of the issue, there's like 20 threads per day on the LTT forums that are just titled some variation of "help me."
I got it 4 days ago. And that’s what I thought they should be white indicating that it has correct power consumption. I read that it was cause I didn’t have enough power so I got an 850 watt gold rated power supply and hooked it up and still the same problem.
and I’m new here and never had to do this before so apologies on the title.
https://linustechtips.com/topic/1311916-someone-help/#findComment-14533726
Did you buy it brand new or "open box"?
What specific models of PSU have you used? "850W gold" doesn't mean much.
https://linustechtips.com/topic/1311916-someone-help/#findComment-14533731
One of the +2 pins is not connected properly it looks like.
It should be flush with the 6-pin block, but it's crooked in your picture.
RTX 2080 Super in 2021?
Sounds like a "Used" or "Open Box" item...
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/1311916-someone-help/#findComment-14533749
It was an open box. Finding a GPU now days seems like impossible so I jumped on the opportunity. And the model I have in right now is 850W EVGA GQ
https://linustechtips.com/topic/1311916-someone-help/#findComment-14533803
Correct the crooked +2 pin connector -Rascal- mentioned. If that doesn't make a difference, return the card. Seems likely there was a reason someone returned it before and it ended up as open box, and if someone returning a defective part to Micro Center doesn't tell them there's a specific problem I don't think they test it much at all.
https://linustechtips.com/topic/1311916-someone-help/#findComment-14533812
Okay I will test that. Thank you for your guys help.
https://linustechtips.com/topic/1311916-someone-help/#findComment-14533821
