Build won't POST, EZ Debug CPU LED
So After a few days of troubleshooting by myself, sending both Motherboard and CPU back, I can't seem t figure out what the issue is.
Build
CPU: R9 3900x
Motherboard: Msi MPG X570 Gaming Pro Carbon Wifi
Ram: TridentZ RBG 3200hz (2x16GB)
GPU: Zotac 2060 super
PSU: Corsair HX 850
SSD: Samsung 970 M.2 1TB
AIO: NZXT Kraken Z73
What I have done so far
- Replaced Both CPU and Motherboard
- Used stock fan
- Used 1 Ram stick
- Used different Ram sticks (they were also slower)
- No GPU
- Both 8pin and 4pin on Motherboard
- Swapped out PSU
- Swapped out PSU cables
- Reset CMOS and Changed CMOS battery
- Tried M.2, SSD and HDD
Results
Basically, the Debug LED for the CPU still remains on and the system powers off after 5 to 8 seconds.
I was thinking maybe it was just the pump but it still happens with the fan that comes with the CPU.
Everything else turns on just fine, the pump and radiator fans, GPU, Ram, and even heatsink for the M.2.
I would really appreciate any help even if it yields no results.
Thank you for taking the time.
Fix
Orientating it off my test bench fixed it, it seems that the pins weren't contacting the board enough.
