skyrim help
Read the last few lines. Thats were it terminates and is therefore your problem area. To me, it looks like you're missing Unofficial Skyrim Patch. Which is a master for Unofficial Dragonborn patch. If you don't have a master for a mod loaded before said mod, you're gonna have a bad day.
The only requirement after installation is to move Unofficial Dragonborn Patch.esp to the top of the load order, below the Unofficial Skyrim Patch.esp, below the Unofficial Dawnguard Patch.esp, and below the Unofficial Hearthfire Patch.esp in Data Files in the Skyrim launcher (above any other ESP files) so that the UDBP loads as close to first as is practical. This will allow other mods to override its changes so that it doesn't cause problems with them. Use of BOSS is highly recommended since it will position the patch correctly along with your other mods as well.
Example load order:
Skyrim.esm
Update.esm
Dawnguard.esm
Hearthfires.esm
Dragonborn.esm
HighResTexturePack01.esp
HighResTexturePack02.esp
HighResTexturePack03.esp
Unofficial High Resolution Patch.esp
