I just finished a pc build and when I pressed the power button nothing happened. The motherboard leds and the graphics card leds light up when the power supply is on, but when the power button is pressed nothing happens. No fans spin or light up. I’ve already tried using a screwdriver to start the pc and I don’t have a reset switch to swap with the power switch. Please help
https://linustechtips.com/topic/1309470-pc-will-not-turn-on/
Did you plug in your 24 pin connector and your 8 pin CPU connector?
Quote or tag me( @SEAL62 ) if you want me to see your reply
consider a reaction if I was funny, informative, helpful, or agreeable
OS: Windows 10 Pro
CPU: Intel i9-9900K GPU: Aorus GeForce RTX 3080 Master Motherboard: Gigabyte Z390 Aorus Master
AIO: Corsair H150i RGB Platinum RAM: Corsair Vengeance RGB Pro 32GB 3000MHz Case: Corsair iCUE 465X RGB PSU: Corsair RM750x White
OS: Kali Linux
HP Envy x360 Convertible
CPU: Intel i5-10210U GPU: NVIDIA GeForce MX250 RAM: 16 GB DDR4 2666 SSD: 512GB PCIe
https://linustechtips.com/topic/1309470-pc-will-not-turn-on/#findComment-14513117
Does your mobo have any speaker that would provide a beep pattern that could indicate what the problem is?
OS: Windows 10 Pro
OS: Kali Linux
https://linustechtips.com/topic/1309470-pc-will-not-turn-on/#findComment-14513130
Hm, the mobo does have pins for a speaker but there's probably none attached.
Hard to say with these little information, could be a CPU issue or have something to do with the PSU.
Do you have spare RAm to test if that is ok? Or onboard graphics to see if your GPU may cause the problem?
OS: Windows 10 Pro
OS: Kali Linux
https://linustechtips.com/topic/1309470-pc-will-not-turn-on/#findComment-14513196
Unfortunately no I’m thinking of just taking it to a repair shop to see if maybe someone can help in person
https://linustechtips.com/topic/1309470-pc-will-not-turn-on/#findComment-14513231
sounds liek a good idea but check reviews of those repair shops first so you won't get scammed by someone who thinks that people who don't know everything about tech are easy earned money.
OS: Windows 10 Pro
OS: Kali Linux
https://linustechtips.com/topic/1309470-pc-will-not-turn-on/#findComment-14513242
Alright thanks for the help 🙂
https://linustechtips.com/topic/1309470-pc-will-not-turn-on/#findComment-14513265
No problem 🙂 Sorry I couldn't do more.
I would be very happy if you would react to some of my posts (Like/Agree something like that) and/or mark one as the answer to your question.
OS: Windows 10 Pro
OS: Kali Linux
https://linustechtips.com/topic/1309470-pc-will-not-turn-on/#findComment-14513270
