VENGEANCE® LPX 16GB (2 x 8GB) DDR4 DRAM 3200MHz C16. not running 3200mhz, on gigabyte x570 gaming x.
Solved by Guest,
2 minutes ago, eatingaerailshoppingcenter said:yes i have i updated it to f33c, im just about to try f32.
It's not the bios.
The Cpu memory controller is only rated to 2933mhz.
Set XMP, but manually lower the Dram freq. to 2933mhz.
Be sure to set memory voltage to XMP manually.
You can also disable "power down mode" located in the memory sub timings menu.
If the memory is an odd number Cas latency, you can also disable "gear down mode".
Let me know if this works for you.
