hi lemme start off i just rebuilt my pc i have a 2070 i5 9600k and a asus prme z390 a it worked fine performace wise on my old pc but now its really bad i installed all drivers and its still dosent work im getting around 30 to 60 fps on rust and on my old old pc i was getting 60 to 80 on a r5 1600 and rx 580 and on valorant i have been getting under 144 fps i checked thermals and everyhthing is applied good my usual temp while playing games is 40 degrees celcius and idle like 15 to 30 i really need help with this i also tried overlclocking and i didn't really help that much i just reaaly need help please and thank you
https://linustechtips.com/topic/1308352-i-need-help-with-my-pc/
Check your Task Manager. What is keeping your system busy and what components does it affect? Maybe there are some Windows updates running in the background, maybe some software is faulty and causes overuse of resources. Really can only guess with the info you provided
Quote or tag me( @SEAL62 ) if you want me to see your reply
consider a reaction if I was funny, informative, helpful, or agreeable
OS: Windows 10 Pro
CPU: Intel i9-9900K GPU: Aorus GeForce RTX 3080 Master Motherboard: Gigabyte Z390 Aorus Master
AIO: Corsair H150i RGB Platinum RAM: Corsair Vengeance RGB Pro 32GB 3000MHz Case: Corsair iCUE 465X RGB PSU: Corsair RM750x White
OS: Kali Linux
HP Envy x360 Convertible
CPU: Intel i5-10210U GPU: NVIDIA GeForce MX250 RAM: 16 GB DDR4 2666 SSD: 512GB PCIe
https://linustechtips.com/topic/1308352-i-need-help-with-my-pc/#findComment-14503789
