Budget (including currency):
Country: Finland
Games, programs or workloads that it will be used for: Latest games
Ryzen 5 5600x with Cooler Master Hyper 212
Rtx 3060 Ti
1TB SSD M.2
B550-F Gaming motherboard
2x8 GB RAM @3200mhz
700W Kolink Gold certified PSU
NZXT H510 case
144hz screen
Just want general opinions :)
https://linustechtips.com/topic/1308157-solid-pc-build/
https://linustechtips.com/topic/1308157-solid-pc-build/#findComment-14502377
4 minutes ago, lee32uk said:
Avoid the B450-F though. The B550-F is much better.
Agreed, especially if you want to put in ram faster than 3200Mhz you need B550-F
current PC:
PC configs I used before:
https://linustechtips.com/topic/1308157-solid-pc-build/#findComment-14502384
Country: Finland
Rtx 3060 Ti
1TB SSD M.2
2x8 GB RAM @3200mhz
NZXT H510 case
144hz screen
Just want general opinions 🙂
5600x kind of overpaid, why don't u downgrade to 3600 and get 3070,
assuming that's possible, GPU market is kind of Meh
https://linustechtips.com/topic/1308157-solid-pc-build/#findComment-14502386
I have thougt about that option but the 3070 is x2 more expensive than the 3060 I can get. While the 5600x is only about 120€ more expensive than the 3600 🙂
https://linustechtips.com/topic/1308157-solid-pc-build/#findComment-14502511
1 minute ago, Nelzbef said:
Btw! May I ask why 3600mhz is better than 3200mhz in this build? I’m new to pc building
its simple
more faster more better
of course there are a lot of * in that sentence but its pretty much what it boils down to
if it was useful give it a like :) btw if your into linux pay a visit here
https://linustechtips.com/topic/1308157-solid-pc-build/#findComment-14502518
