Does overclocking cpu increase fps?
Go to solution Solved by Mark Kaine,
if you're cpu limited then yes, otherwise probably not by much, and 0.2 ghz is very little anyways.
Imo not worth the trouble (shooting) that will probably occur.
2 minutes ago, ninjaboyxd629 said:
i want to oc my a8 6600k from 3.9 to 4.1 do you think is it worth it? and how much fps will it increase?
It depends on the game and rest of your system. Overclocking your CPU is not the be all end all. If your GPU for instance isn't up to snuff, overclocking your CPU all the way to 5GHz ain't gonna do anything.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
thats a bad idea because im using stock cooler
-Scott Manley, 2021
