[spoiler=»--((¯`·._.·¤~●oO му яιg Oo●~¤·._.·´¯))--«] Case: Corsair 600T White       CPU: Core i7 3930k @ 4.3GHz                     SSD: Crucial M500 480GB
MB:    Asus P9X79 LE         GPU: Nvidia GTX 780 Reference             HDD: WD Caviar Green 3TB
PSU:   Seasonic X-1050      RAM: G.Skill Trident X 32GB @ 2.4GHz   ☃ There are 10 types of people in this world. Those who understand binary and those who don't.
https://linustechtips.com/topic/130710-system-high-cpu-usage/
Okay... Is something wrong or...
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/130710-system-high-cpu-usage/#findComment-1739965
are you going to post more info? was this right after startup? what CPU do you have?
He has 3930K@4.3 Ghz... And to the topic, maybe windows is just installing some updates or something because that usually is under "system"
CPU: AMD R7 5800x | GPU: XFX 5500XT 4GB | RAM: 2x8GB Kingston Fury Renegade 3600MHz CL16 | Cooling: Deepcool Gammaxx L360 | MB: Aorus B550 Elite V2 | Storage: Samsung 850 Evo 250gb & WD20EAZX | Case: Antec DF700
Lenovo ThinkPad Yoga 460: Intel 6200U | 8GB | 256GB SSD | Active pen
https://linustechtips.com/topic/130710-system-high-cpu-usage/#findComment-1739973
are you going to post more info? was this right after startup? is this constant or does it go away?
Computer has been on for 119.2 hours. It's been like that for ~14 hours now.
https://linustechtips.com/topic/130710-system-high-cpu-usage/#findComment-1739974
your disk must be really badass, to have a 0% utilization percentage while reading/writing 4 GB per second
LOL, didnt notice that... Ok, theres probably something wrong with the windows...
https://linustechtips.com/topic/130710-system-high-cpu-usage/#findComment-1739977
Windows is not installing any updates.
https://linustechtips.com/topic/130710-system-high-cpu-usage/#findComment-1739978
why is it on for so long? there could be unnecessary things running in the backround. you could run ccleaner and see if your windows installation is using too much space or something
https://linustechtips.com/topic/130710-system-high-cpu-usage/#findComment-1739983
well its doing something since we can see that 3.9 gigs/s on the drive
https://linustechtips.com/topic/130710-system-high-cpu-usage/#findComment-1739987
https://linustechtips.com/topic/130710-system-high-cpu-usage/#findComment-1739997
How about a reboot? Does that fix it?
Yes, but only for a couple hours. This usually happens after 80 hours uptime.
https://linustechtips.com/topic/130710-system-high-cpu-usage/#findComment-1740000
ok, it seems like there aren't any useless files lying around, could you also check the registry?
Check the registry for what?
https://linustechtips.com/topic/130710-system-high-cpu-usage/#findComment-1740013
That's because standard computer parts aren't meant to be on 24 hours a day,unless you're using a server/workstation motherboard, xeon processor, server/workstation grade HDD, etc. you shouldn't expect it to run flawlessly for days on end.
Linus Sebastian said:
The stand is indeed made of metal but I wouldn't drive my car over a bridge made of it.
https://youtu.be/X5YXWqhL9ik?t=552
https://linustechtips.com/topic/130710-system-high-cpu-usage/#findComment-1740834
