Warzone keeps crashing.. :( please help!!
My Warzone keeps crashing for some reason :( it usually happens 3 or 4 times a day, the first crash doesn't give me an error or anything it simply just closes the game then the second and more crashes either give me a disc error 3.1 or a dev error.. I've tried every suggestion in existince like uninstalling etc etc and it still happens :( dont know what to do i am going crazy!! pelase help!!
Specs:
AMD 9 3900XT
RTX 3080 FE
32gb ram 3600mhz
512 M.2 SSD
3TB HDD
Thank you in advance!
https://linustechtips.com/topic/1306473-warzone-keeps-crashing-please-help/
You'll have to be more descriptive with those errors. Can you provide screenshots?
What does Event Viewer say?
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2 - Windows 11 Pro
1 minute ago, jtx said:
My Warzone keeps crashing for some reason 😞 it usually happens 3 or 4 times a day, the first crash doesn't give me an error or anything it simply just closes the game then the second and more crashes either give me a disc error 3.1 or a dev error.. I've tried every suggestion in existince like uninstalling etc etc and it still happens 😞 dont know what to do i am going crazy!! pelase help!!
Specs:
AMD 9 3900XT
RTX 3080 FE
32gb ram 3600mhz
512 M.2 SSD
3TB HDD
Have you tried resetting the bios
Errors:
https://ibb.co/3kCyG2C
https://ibb.co/2vkJgR4
https://ibb.co/9bz4DSy
https://ibb.co/YWmZmzR
Not sure what Event viewer is? sorry
Just now, jtx said:
Ok, fairly certain your game install is corrupted, your drive you have it installed on is failing or your memory is failing.
That's pretty evident from those error messages.
What drive is the game installed on?
The game is installed in my 512GB M.2 SSD, i only have Windows, Warzone and CS:GO installed in it.. and i only experience the crashes with Warzone.. i can play 6+ hours of CS:GO without a single crash..
This issue should be easy to isolate. I know this is easier said than done for some people with Warzone being so big (i'm on Gigabit fiber so its not that bad) but I would suggest totally removing Warzone from that drive and installing it on your other one.
You're at a point now where you need to narrow things down. There game is complaining errors loading files so lets move the files to a completely new drive and see what happens.
Do NOT try to actually move the files yourself, it'll have to be redownloaded to ensure you're getting a fresh copy.
Should i go ahead and uninstall it and delete everything warzone related in my m.2 and install it in my HDD?
Yes. If you can get the game installed, running and error free on the HDD, you can always try reinstalling it on the SSD later on but we're trying to narrow down what's going on here and this is just step one.
Doing that now, thank you!
Will update here when it's intalled!
Played 2 games today and got this error: https://ibb.co/8Y0qs4Y 😞, i played for a good 4 hours yesterday after installing it on the HDD without any errors
You may want to verify your memory. If you download the free version here, it includes a PDF with how to make a bootable USB stick in the included PDF on page 6.
https://www.memtest86.com/download.htm
Happening on both drives makes me think its something system related.
Did this and it gave me errors while having the 4 sticks of ram installed. I then removed 2 sticks and did the test again with no errors so I removed the 2 first sticks and then installed the other 2 sticks with no errors either, super strange. It gave errors while the 4 were connected but not when testing 2 at a time? Any idea?
I installed all 4 sticks once again and run the rest with no errors.. I don’t know what’s going on? Why did the first time I did the test I got a bunch of errors? (The test crashed because of the amount of errors it had, lol) but after testing 2 at a time and now all 4 again and no errors?
4 hours ago, jtx said:
That link doesn't work (requires you to sign into Slack) but you almost certainly have bad RAM and that makes a lot of sense given the errors you're getting.
If you have another system with working RAM you can swap in, that would be a good test, otherwise you might want to replace your RAM.
You can run the full test with only one stick installed at a time to see if you can find the faulty stick(s).
