CPU running at half speed
Go to solution Solved by The Third Thomas,
Why is my CPU running at 1.6 GHz?
Normally it's running 4.1 when active, but today it just suddenly dropped to 1.6, I checked because my pc felt a little sluggish. Haven't seen it go over 2.1 in about half an hour yet.
4 minutes ago, StixuYT said:
The CPU will limit the frequency to what it's needed, for example you can open a game that's CPU heavy(ex.CSGO) and Alt+Tab to see the frequency it's running at. It will most likely be around 3.9-4.0(If you're In-Game)
Yeah the problem was that my League of legends normally runs at 200+ fps, and now it was running at 40 with constant stuttering.
2nd restart fixed the problem.
Install Ryzen Chipset driver and select Ryzen balanced in power option.
