rx 6800 xt - nicehash 0% load
xxx68
Screenshot_2021-02-14-00-31-16-758_com.nicehash.metallum.thumb.jpg.1a4702606b1a6ba240d451ac4c9b84a3.jpg
hello, I just tried nicehash and it shows  0% load with my rx 6800 xt. But it shows actual number at profitability/24h. Is my gpu mining ? Or what should I do ? DDU driver reinstall didnt help.  Cpu is running 100%. thanks
Yes it's running, just not able to read usage (and temp for that matter) on AMD it seems.
F@H
GPD Win 2
Thinking of doing this with my 6800XT but worried that it might damage my card?
CPU i7 14700K | CPU Cooler Noctua NH-U12A | Motherboard MSI Pro Z690-A | GPU Zotac Airo RTX 4080 | RAM 32 GB GSkill Ripjaws V 4400
Mhz |
 Monitor Alienware AW2721D / Gigabyte M28U | PSU ASUS ROG Strix 850G
If you’re scared about a piece of hardware being used, then you should prolly sell it.
Main RIg Corsair Air 540, I7 9900k, ASUS ROG Maximus XI Hero, G.Skill Ripjaws 3600 32GB, 3090FE, EVGA 1000G5, Acer Nitro XZ3 2560 x 1440@240hz
Like stated, it’s just a bug right now.
Assume the usage it maxed out. And you should watching temps on another program anyway for the Oc settings.
