Hi all,
Im having issues with my 3080 in certain games. I will be playing apex and in menus and while flying in i will have 100% gpu usage but ass soon as I land and go anywhere it hover around 50%. This seems weird. My CPU never hits 100%
My specs are
Ryzen 2700x
16gb 3000Mhz Ram
3080 Suprim x
850 prime gold plus
Let me know if you have any suggestions... Thanks!
https://linustechtips.com/topic/1305571-not-using-100-gpu-with-3080/
10 minutes ago, DxRalph said:
It does,
Shadow of war has the same, rise of the tomb raider has it too... I should be getting more than 144 fps in apex I feel
If you're only getting 144fps then you've got some sort of frame limiting enabled. The reason your usage isn't 100% is because you've effectively told your graphics card don't render anything more than 144 frames a second, and so despite it being capable of more its not. Thus the lower usage.
Indeed if you have something like v sync enabled then it must be it ... if not ... If you don't get to 100% gpu usage of close to that you are most likely cpu bottlenecked ... I don't really know how apex use the core of the cpu but you most likely have at least one or two cores (maybe more too) that are often pinned to close to 100% and the rest sitting idle or not doing much.
I9 10850K
EVGA RTX 3080 TI FTW3 ULTRA
32 Gb Crucial Balistix ddr4 3600mHz 16-18-18-38
MSI Z490 Tomahawk
Fractal Design Ion+ 860W platinum
Arctic Liquid Freezer II, 360mm
WB Black SN750 NVMe ssd
TeamGroup L5 3D Lite 1 Tb sata SSD
it's surprisingly hard to find info on apex on older amd cpus
Apex Legends - RTX 3080 + R5 3600 - 1080p, 1440p & 4K - High & Low Settings - Season 6 - YouTube
it's a slight cpu bottleneck, the cpu doesn't need to be at 100%
from what ive seen it dips under 144fps, alot, the game's pretty cpu intensive, wouldnt worry too much about it.
Though there was some1 with a really tuned 2700x at 4.2ghz and 32gb of ram getting 130-160 instead of 110-140.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
Just to clarify, It does go above and below 144 fps, and i think the highest my cores have gone is about 85%. Maybe you are right and its causing a small bottleneck. Would a 5600x be a big upgrade in this case? all frame rates are unlocked and never any vsync. What about the other games? they never use all of my gpu when Heaven benchmark does. same issue? I presume so
Heaven is a gpu stress test, it's meant to use the gpu to it's full capabilities ... if you don't see 100% usage in other task it's that something is preventing it ... be it a fps limitation or bottleneck from somewhere ...
The 5600x would be (if you can find one) a good upgrade as the ipc is better than the 2700x.  It's still rare for games to use all the 8 cores of a cpu so the 5600x would probably serves you better than your current 2700x.
I9 10850K
MSI Z490 Tomahawk
Some games will be CPU limited
Some will be network limited
high end GPUs are more helpful for single player games in my experience.
i5-14600KF // 120x38MM Cooler Master AIO // B760i // 64GB DDR5 6000 // PNY RTX 5070 // Cooler Master NCORE 100 Max // Cooler Master V SFX-850 Gold // UWQHD AOC Display
