I need help identifying these drives and extra points if you tell me what the purpose of the copper thingy under is
Reminder⚠️
I'm just speaking from experience so what I say may not work 100%
Please try searching up the answer before you post here but I am always glad to help
https://linustechtips.com/topic/1304148-need-help-identifying-these-drives/
1 minute ago, Levent said:
So what is an SCSI drive?
Reminder⚠️
SCSI was like IDE, but faster and had external variants.
I've got a similar drive to #2, except it's a bit different (IBM 45G9567 or something like that).
It's got the same 50-pin connector, same copper band, and it's 1GB.
If it works, it's worth $200.
#2 is also SCSI, but uses a different connector.
I don't know what the band is for.
PLEASE STOP [Killing] ME I WILL GIVE Y OU ANOTHER DEAL.
I have like 5 of these drives but have no way to test if they work lol
Reminder⚠️
I have a PCI SCSI card that can connect to them.
If you have a computer with PCI slots I can send you a link to test them (you'll need cables though).
I would offer to test them for you but (unless your location is false) I don't think I'll be going to Sweden anytime soon.
Yeah I might skip testing them since they most likely won’t work since I got a bog of drives I got and it had been in a garage
Reminder⚠️
Probably not.
They look cool, though.,\
Probably not.
Yeah, a question about IDE drives does the head move if I have just the molex cable in?
Reminder⚠️
I don't believe so.
I'm not sure if the drive spins up either, though it will draw power.
I don't believe so.
Though it will draw power.
Okay so to get it to move I just have to plug it in and like open it in explorer?
Reminder⚠️
Do you have a working IDE or SCSI controller?
If not, you'll need one. The drives can't communicate across only Molex.
I know, I have an IDE cable
Reminder⚠️
IDE is not compatible with SCSI.
I know but I’m talking IDE drive now (sorry for confusing you)
Reminder⚠️
Ah.
Ok.
As long as you have an IDE controller connected to your computer and the drives, and the jumpers are set, you're good.
To set jumpers:
There should be a group of 6 or 10 pins by themselves, with 2 labeled CS or Cable Select, 2 labeled MS or Master, and 2 labeled SL, or Slave.
If you only have 1 drive, short the 2 Master pins with a little jumper.
If you have 2 drives, set 1 to master and 1 to slave.
2 minutes ago, ragnarok0273 said:
Ah.
Ok.
To set jumpers:
If I have 3? Does it even work?
Reminder⚠️
I don't think there were any 3-device IDE controllers, so you can only do 2 at a time on one controller.
If you have 2 IDE controllers, though, you can put one drive on its own controller.
