Hello,
I was gaming as usual yesterdays and then suddenly pc Just shut it self off.
Then it imediatly turns itself back on but there is nothing on the monitor.
I have checked all connections inside the computer. Removed and re inserted the gpu but still nothing on the monitor. VGA LED light up on mb, manual says Its a problem with the Graphics Card. I get image via mb VGA output.
Did my few months old gpu Just die out of nowhere? I have had No problems or anything noticeable before this.
Do anyone have any tips? Or is it dead.
Specs:
Gigabyte Rtx 3090
Intel I9 10900k
Gigabyte Z490 GAMING X
G.Skill Ripjaws V DDR4 16GB KIT 3200Mh
Cougar GEX 850 w psu
https://linustechtips.com/topic/1303061-please-help-dead-3090/
2 minutes ago, SondreNorway93 said:
Hello,
Specs:
Gigabyte Rtx 3090
Intel I9 10900k
Do you have a different PSU that you can use?
PLEASE STOP [Killing] ME I WILL GIVE Y OU ANOTHER DEAL.
https://linustechtips.com/topic/1303061-please-help-dead-3090/#findComment-14461335
try without the gpu and use intergrated graphics on the cpu. plug the cable in the motherboard without the dedicated gpu in the pc.
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1303061-please-help-dead-3090/#findComment-14461343
Just now, SondreNorway93 said:
I did that, that works
now try with the gpu on. if ti does not work then
try a different slot on the mobo
different power cables
https://linustechtips.com/topic/1303061-please-help-dead-3090/#findComment-14461349
With a multimeter? GPU do get power fans spin
oh. well try with idfferent power cables first. if not work different slot.
otherwise your gpu probably died.
could be the psu and mobo but very slight change
https://linustechtips.com/topic/1303061-please-help-dead-3090/#findComment-14461366
Update.
Is it normal that one of the PCI pins is different than the other? Look at video.
Look at your own video, it's impossible to see whatever it is you're trying to call attention to through that distorted mess.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
https://linustechtips.com/topic/1303061-please-help-dead-3090/#findComment-14469871
6 minutes ago, SondreNorway93 said:
Update.
I think i can see a bent pin. Right hand side connector. On the bottom row. Second from the left. It looks all bent out of shape.
https://linustechtips.com/topic/1303061-please-help-dead-3090/#findComment-14469879
Ywa Its pretty weird, but gpu did stay in the pc for months and nothing happend Linda weird it happends out of nowhere if this is the cause of my problems.
https://linustechtips.com/topic/1303061-please-help-dead-3090/#findComment-14469894
