5800X Instantly hits TJMax at load
RIG_
Under the advice of LTT I upgraded my CPU to a Ryzen 5800X (full specifications below).
Idle, my CPU is 40-50°C.
However, whenever I run 'stress --cpu 16' my CPU goes up to 90°C () within 5 seconds and then stays there (as reported by XSensors).
I have a Corsair h80i v2 AIO (tier 2 cooler). Originally, I used the wrong AMD motherboard stand-offs and replaced these with the correct AM4 motherboard stand-offs. The cooler is installed in the rear of the case with the tubes at the bottom. I bought some Arctic silver 5 to replace the pre-applied thermal paste.
Could I have cleaned the CPU poorly when I changed the standoffs? It looked clean.
Could the screws on the CPU block be too loose? I didn't want to over-tighten them.
Motherboard wise, I'm using the MSI mortar Wi-Fi, running BIOS version '7C94v15' (the latest available BIOS).
I haven't changed anything except made the fan curves more extreme and turned XMP on.
I'm using Manjaro Nibia 20.2.1 GNOME edition with kernel 5.10.7-3.
Any and all suggestions will be greatly appreciated.
Even if it is tier 2 single fan AIOs are pretty bad.
Also that cpu runs hotter than 5900x sicne it has only 1 CXX (which is better than 2 on the 5900x) Also that cpu has the best single core performance in the world right now.
what i am saying is that your temps are expected.
QUOTE ME  FOR ANSWER.
Main PC:
|Ryzen 7 3700x, OC to 4.2ghz @1.3V, 67C, or 4.4ghz @1.456V, 87C || Asus strix 5700 XT, +50 core, +50 memory, +50 power (not a great overclocker) || Asus Strix b550-A || G.skill trident Z Neo rgb 32gb 3600mhz cl16-19-19-19-39, oc to 3733mhz with the same timings || Cooler Master ml360 RGB AIO || Phanteks P500A Digital || Thermaltake ToughPower grand RGB750w 80+gold || Samsung 850 250gb and Adata SX 6000 Lite 500gb || Toshiba 5400rpm 1tb || Asus Rog Theta 7.1 || Asus Rog claymore || Asus Gladius 2 origin gaming mouse || Monitor 1 Asus 1080p 144hz || Monitor 2 AOC 1080p 75hz ||
Test Rig.
Ryzen 5 3400G || Gigabyte b450 S2H || Hyper X fury 2x4gb 2666mhz cl 16 ||Stock cooler || Antec NX100 || Silverstone essential 400w || Transgend SSD 220s 480gb ||
Just Sold
| i3 9100F || Msi Gaming X gtx 1050 TI || MSI Z390 A-Pro || Kingston 1x16gb 2400mhz cl17 || Stock cooler || Kolink Horizon RGB || Corsair CV 550w || Pny CS900 120gb ||
Tier lists for building a PC.
Motherboard tier list. Tier A for overclocking 5950x. Tier B for overclocking 5900x, Tier C for overclocking 5800X. Tier D for overclocking 5600X. Tier F for 4/6 core Cpus at stock. Tier E avoid.
(Also case airflow matter or if you are using Downcraft air cooler)
Gpu tier list. Rtx 3000 and RX 6000 not included since not so many reviews. Tier S for Water cooling. Tier A and B for overcloking. Tier C stock and Tier D avoid.
( You can overclock Tier C just fine, but it can get very loud, that is why it is not recommended for overclocking, same with tier D)
Psu tier List. Tier A for Rtx 3000, Vega and RX 6000. Tier B For anything else. Tier C cheap/IGPU. Tier D and E avoid.
(RTX 3000/ RX 6000 Might run just fine with higher wattage tier B unit, Rtx 3070 runs fine with tier B units)
Cpu cooler tier list. Tier 1&2 for power hungry Cpus with Overclock. Tier 3&4 for overclocking Ryzen 3,5,7 or lower power Intel Cpus. Tier 5 for overclocking low end Cpus or 4/6 core Ryzen. Tier 6&7 for stock. Tier 8&9 Ryzen stock cooler performance. Do not waste your money!
Storage tier List. Tier A for Moving files/  OS. Tier B for OS/Games. Tier C for games. Tier D budget Pcs. Tier E if on sale not the worst but not good.
(With a grain of salt, I use tier C for OS myself)
Case Tier List. Work In Progress. Most Phanteks airflow series cases already done!
Ask me anything :)
The screws holding the block on should be tightened all the way, the standoffs are sized such that it's not possible to overtighten them. 90*C under stress test doesn't sound unreasonable for that CPU paired with that cooler though. How does it fare under real-world load?
Powerspec 1530 (Clevo PB50DF2) ~ i7 10875H ~ RTX 2070 Super 115W ~ 32GB DDR4 ~ 2x 1TB NVMe ~ 2TB 5400RPM ~ 1080P 240hz matte IPS
Gigabyte G1 GA-970-SLI ~ FX 8320 @ 3.3Ghz, 1212mV ~ 16GB DDR3 ~ Radeon 570 4GB ~ 512GB NVMe ~ 2x 1TB HGST 7200RPM
Xtras ~ Dell 22" 1680x1050 matte IPS monitor ~ Logi M705 mouse ~ PowerA Fusion Pro Xbox One controller ~ Sony XB950N1 headphones ~ Epson V700 film scanner
Streaming Setup ~ OBS Studio with AMF encoding ~ iVCam bridged to LG G6 ~ Focusrite Scarlett Solo interface ~ TONOR condenser cardioid mic
The h80 is basically the performance of a hyper 212 which is barely good enough for a 5800x. So yeah not the right cooler.
I do not get why it is at tier 2 tho?
Main PC:
Test Rig.
Just Sold
Ask me anything :)
Same honestly. Maybe because it's a decent cooler for certain itx cases? But then again that would make the tier list a bit odd.
So the h80i v2 has 2x fans and is a double thickness radiator, I don't think I can return it now that it's been used so I'm stuck with it.
Is it worth purchasing better case fans / a better case and undervolting the CPU?
I don't want to cook the CPU, I will probably be using it for the next 10 years!
I heard they changed the safe temp range for the new 50xx series, what temp range would be considered safe?
