How easily can I mess up while building
Solved by JamesTheFolf,
Just now, SquiddyButler said:PSU: Corsair RM850x
HD: WD 2TB
Motherboard: Z490-E
Ram: Corsair Vengeance RGB Pro 16GB
Case Fan: Silent Wings 3
Case: Phanteks P500A
Cooler: Noctua NH-D15
CPU: i9 10850k unlocked
GPU: Zotac AMP Holo 3070
This is what you meant, correct?
Yeah that is what I was meaning. So the worst thing you could damage is the cpu socket, while installing the cpu into the socket. If you're unsure of how to install the CPU, I'm going to attach a video you can watch.
