Cougar QBX case air flow question
I have a fan orientation question for the Cougar QBX case and trying to decide on how I should set the fans for the best possible cooling. I'm using a Gigabyte A620i MB with Ryzen 8600g. The CPU cooler is a be quiet! Shadow Rock LP cooler. I'm also trying to make it as quiet as possible too.
Would it be better to install the 80mm in the front and use the 92mm in the rear of the case or do an intake 120mm on the bottom of the case and exhaust 120mm at the top of the case?
The specs says a max of 7 fans. 1 rear exhaust fan pre-installed.
https://cougargaming.com/products/cases2/qbx/
