seems to be a sort a "antenna" wave interference, are others neighbor using 2.4 GHz wifi if you know by any chance?
also did you try switching channels to your router?
Make sure to quote me if you want me to respond
Turn your Mobile VR or PSVR Headset into a working 6DoF SteamVR one guide/tutorial (below):
My PC
https://linustechtips.com/topic/1301776-wifi-cutting-out/#findComment-14451245
I forgot to quote lol also other neighbors do use 2.4ghz as far as i know
https://linustechtips.com/topic/1301776-wifi-cutting-out/#findComment-14451319
alright have you done any basic troubleshooting like switching channels or resetting your router or something?
My PC
https://linustechtips.com/topic/1301776-wifi-cutting-out/#findComment-14451821
14 hours ago, SGT-AMD said:
If you are turning things on and the wi-fi is going away, that indicates a poor signal to noise ratio.
1. How far away are you from the router?
I believe that you have something new in the house that may be making some noise.
One way to troubleshoot is to turn off all circuit breakers that are not important to your router and cable modem. Then, turn them on one at a time to see which circuit (might) be creating the issue. Look for switiching power supplies and led lights
on that circuit and unplug and unscrew the lights.
Doorbell cameras are something to look at as well.
All the wifi in the ENTIRE house just crashes. On the router it says that there is internet. I dont remember anything new that makes noise.  I believe that there is a light/camera for our neighbors that turns on by motion(the light turns on by motion idk if the camera does). I would try the circuit breakers thing but its very hard since it happens randomly sometimes 2-4 times a day sometimes 2 times a week
https://linustechtips.com/topic/1301776-wifi-cutting-out/#findComment-14454226
I could switch channels but accord to a wifi analyzer there isnt really alot of networks (5 including me) at once. Most of the times its 2-3. It changes by me walking around the house lol. If u want i can send screenshots.
https://linustechtips.com/topic/1301776-wifi-cutting-out/#findComment-14454229
2.4 Ghz isn't just used by WiFi. Other devices use it as well. Just like part of the 5Ghz spectrum is used by Radar. These are things that WiFi analyzer wont show you. To be honest, I wouldn't touch 2.4Ghz with a 30 foot pole if 5Gzh was available.
https://linustechtips.com/topic/1301776-wifi-cutting-out/#findComment-14454622
Pretty sure its not available
https://linustechtips.com/topic/1301776-wifi-cutting-out/#findComment-14455080
Just now, Killer183 said:
pretty sure it does but idk if my internet does
If the router supports 5Ghz that’s all you need. Your ISP has nothing to do with what bands you can use, that’s all dictated by the equipment you use.
https://linustechtips.com/topic/1301776-wifi-cutting-out/#findComment-14455209
oh lmao i didnt know that. How do i check if i can change it to 5ghz. Also can i make like 2 wifis one is 5ghz and one is 2.4ghz with the same router?
https://linustechtips.com/topic/1301776-wifi-cutting-out/#findComment-14455216
Check the WiFi settings in the router's firmware. As far as two separate networks go, it depends on the router. My sister has the Google WIFi mesh system, and you cant separate out the networks. However on my router, I have 2 separate networks, I just added the band to the end of the SSID. So I have Donut2.4 and Donut5Ghz, that way I know what network Im connecting to.
https://linustechtips.com/topic/1301776-wifi-cutting-out/#findComment-14456713
I forgot to add that the router is on a ups /battery
https://linustechtips.com/topic/1301776-wifi-cutting-out/#findComment-14460517
17 hours ago, SGT-AMD said:
You could try to elimate the ups, and see what happens, can't hurt at this point.
16 hours ago, Donut417 said:
UPS won't cause an issue. I have my router on a UPS. Works fine.
Yeah i will try to remove the ups but just now like 10 seconds ago i unplugged my ipad from my charger which is like 1 meter  under the router and the wifi cut out for 2 mins. Also what about the ss i sent? Ill try changing the channel to like 11 or 12
https://linustechtips.com/topic/1301776-wifi-cutting-out/#findComment-14463040
45 minutes ago, SGT-AMD said:
His UPS could be raising the noise floor. I do agree that it might not be the issue, but isolation is what we are looking for.
We want to make sure we can find the issue, as I think it might be in the house. I could be wrong as well, but it is a start.
I changed the channel and the wifi didnt cut out when i turned on the laptop. I might have fixed it but ill reply in like 24 hours with a update
https://linustechtips.com/topic/1301776-wifi-cutting-out/#findComment-14463650
9 minutes ago, SGT-AMD said:
I still believe that you have a noise floor issue. Isolating the circuit the noise is coming from will be a step forward.
Again, I could be wrong, but it is the next logical step.
I dont understand how sound would interfer with wifi
https://linustechtips.com/topic/1301776-wifi-cutting-out/#findComment-14466229
