Case Temperature
Solved by Roswell,
Just now, Lutfi 26 said:I want cooler components. What the best I need to besides adding fan?
As far as your CPU goes, full size tower coolers and AIOs are close enough to each other that it doesn't matter which type you get. A full size tower cooler will cost half as much or less than an AIO and also will last a lot longer since they're much more reliable.
The other important thing to look at is your case's airflow. What kind of fan setup do you have? Like, tell us how many intake/exhaust fans you have and where they are in the case.
