Gaming Headset Upgrade Help
Go to solution Solved by Tigerleon,
35 minutes ago, ChaoticChaosx said:
Any other wireless suggestions that are near or better would be appreciated. Wanna to keep the price around $200 USD.
If you don't need wireless. I suggest looking into the Fidelio X2HR with a vmoda boom pro. If you want a mic that is... Vmoda boom pro is a mic/cable hybrid which goes with the headphones to make a headset. These are open back, meaning they leak sound but creates an awesome immersive experience, especially for single player games. They have one of the biggest soundstages out there for the price. The bass is punchy and not too boomy, the mids are balanced and the highs are brighter giving more "sparkle" to the songs or locating footsteps easier.
I need an upgrade from my HyperX cloud II I have used for 5 years now.
Looking at these right now was wondering which would be better if either has any key differences. Sound only no mic needed, I have a quadcast for that. Games are most important single player story driven, occasionally multiplayer such as Warzone, COD. I just trying to find anew headset that gives me the best audio I can get for the money.
Headsets are:
Steelseries Arctis 7
HyperX Cloud II wireless
First watercooled System
Build Name: White Knight
OS: Windows 11 Pro 64-bit
Monitor: Alienware AW3423DWF 1800R Curved Ultrawide 3440x1440 QD-OLED 157hz 10 bit 0.1ms
Chassis: Lian Li 011 Dynamic EVO w/ 2x120mm Corsair QL RGB Fans on the bottom 1x120mm on back exhaust
Top Rad & Fans:  Corsair 54mm 360mm w/ 3x120mm Corsair ML Pro RGB Fans
Side Rad & Fans: Corsair 30mm 360mm w/ 3x120mm Corsair QL RGB Fans
Motherboard: Asrock X670E Steel Legend
CPU: AMD Ryzen 7 7800X3D w/ Corsair XC7 RGB Pro w/ Kyrosheet
Memory/RAM: Corsair Dominator RGB DDR5 2x16GB 32GB 6000Mhz
GPU: Asus GeForce RTX 4080 TUF w/ EK-Quantum Vector2 Nickel/Plexi & Backplate
Pump/Reservoir: Corsair XD5 RGB
Coolant: Corsair Clear
PSU: Lian Li Edge 1000W
Boot/OS SSD: Samsung 970 EVO Plus 500GB NVMe
WZ/2042 SSD: Samsung 850 EVO 250GB
Game SSD: Samsung 980 Pro 1TB
Performance/Editing HDD: Western Digital Black 1TB
Storage HDD: Western Digital Blue 1TB
Mouse: Razer Lancehead Tournament Edition/Razer Mamba
Mouse Mat: Corsair MM700 RGB
Keyboard: Razer Ornata Chroma
Microphone: Beacn Mic
Headset: Razer Blackshark v2 Pro
Eyewear/Glasses: Gunnar Optiks Razer FPS/Gamer Advantage Liquid
Camera: Razer Kiyo Pro/OBSBOT Meet SE
https://linustechtips.com/topic/1301193-gaming-headset-upgrade-help/
6 minutes ago, gnomik said:
Do you really want a gaming headset? If not i would buy AKG k371/k361.
For 200usd you can get the meze 99 neo's or if you go to drop the 99 classics. There nice and thump so they would be good for gunshot sounds in fps games and would also be great for listening to music. Another upside is that there super easy to drive so you wont need an amp or dac.
Headsets are:
HyperX cloud 2 wireless I've heard are pretty good for being wireless.
PM/DM me if you have any questions about audio.
My PC specs & audio gear
CPU > Intel core i7 14700K, GPU > RTX 4070 ProArt, RAM > Corsair Vengeance DDR5 2x16gb 5600mhz, Motherboard > Asus ROG Strix B760-F, Storage > 1TB M.2  & 500GB M.2 Kingston, Cooling > H150i Elite, PSU > MSI A850GL
🎧Current Audio Setup🎧
HifiMan Ananda Nano, HE400se, X2HR
Soundblaster AE-9 Soundcard
AKG P420 Mic
Other peripherals
Monitor > Samsung Odyssey OLED G9
Keyboard > Keychron Q3 HE TKL
Mouse > Logitech G Pro 2 Lightspeed
Mousepad > X-Gamer XG++ XXL mousepad
Read this post if you want a "gaming" headset ;)
AKG P420 Mic
Other peripherals
Well I just been looking at those two for a couple weeks now. I'll look into those though.
Would like to keep it wireless if possible. As for the cloud II wireless I hope the ear cushions are better than the wired version.
However those Fidelio X2HR's look awesome. HUGE ear cushions, main thing is comfortable and sound of course. Open backs are fine with me, I wear gaming glasses sometimes so might be better for not crushing them as my clouds did.
Thank you all for your help & suggestions.
Steelseries just keeps getting me with their "award winning gaming headset" must be the gaming gimmick, but yes I'm really thinking them Fidelio X2HR's and sacrificing wireless.
38 minutes ago, ChaoticChaosx said:
HUGE ear cushions,
They are not only huge, they also are memory foam.
You seem to get it! Gj. And yes, it is a gimmick. The design, mic and software implementation is just awful IMO. Sound is mediocre at best on all their headsets probably. The X2's offer so much more for just 150 euros approximately. You can always get a DAC/amp combo in the future to get even more out of them. Not like they NEED an amp to get loudness out of them but you can miss out on some quality when not amped properly. A DAC will also help clean up any interference inside your PC.
AKG P420 Mic
Other peripherals
Yeah,memory foam sold me there so I know they'll be comfortable as well. I get a DAC now just in case and the amp later on. Thank you. Probably saved me money too. 🙂
A DAC will not be very good without an amp. You need both in order to achieve sound properly. Get something like the Sound Blaster G5 or G3 for a more portable/budget version.
AKG P420 Mic
Other peripherals
Oh yeah, I know and actually those do go together I forgot I had amazon account money so got the headset itself for $50 USD. Definitely afford everything now. lol. So ready! The G5 fits my build so well too. Perfect
