Ok so I just purchased a new PC for my SO and I'm having some problems.
The specs are
Asus x570 prime p
Ryzen 1600
Asus HD 6970
G skill 2x8
Seasonic mkii 750 bronze
Samsung 970 evo
Wd blue hdd.
My computer is basically the same expect with a 1080ti and a 3900x and 4x16 memory.
The issue I'm having is that the PC will shut itself off after a second after 8 pin power is inserted.
The computer lights up and has fan spin when the 24pin is in. I have removed the memory, GPU, ssd, hdd, fans, and all headers besides the power switch. With all of it removed I still have fan spin and lights.
I believe that it is my mobo or cpu. I don't wish to plug in my 3900x to Guinea pig it if the motherboard is faulty as I don't want to break the cpu.
I'd rather not completely rip apart my freshly cable managed pc to trial and error it either, but that's likely what I'm doing.
The cpu and GPU are temporary until they can actually be purchased without being robbed. They are spares I have for troubleshooting. They worked well when I put them away 2 years ago but now idk.
My next step is to put her 1600 in my mobo but I really don't want to do that either cause of my liquid cooler.
I could just return the mobo and start there but this $120 mobo seems to be out of stock unless it's being price gouged for 200$.
Anyone have any useful tips? Before I turn my living room into a hardware warzone?
Side note... my x570 was JUST purchased. I'm thinking that it may have been flashed to support 5000 series and that it no longer supports the 1600. But I do not know the "symptoms" of an incompatible bios. The only way I can think of to test is by putting my 3900x in it, but again I'm scared to put a $500 cpu into a suspect budget motherboard.
https://linustechtips.com/topic/1300890-help-computer-wont-boot/
you have no choice but to do that, its the only way of verifying if its either the cpu that died or the board is toast
Double check that you used the correct 8 pin.
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
Just now, dh465 said:
My pc powers on with her 1600, memory, and psu.
Seems like an rma mobo to me. Anything else I should check before I submit a ticket?
The QVL list for CPUs. None of the 1xxx series is listed anywhere on it. Are you using the same motherboard?
https://www.asus.com/Motherboards-Components/Motherboards/All-series/PRIME-X570-P/HelpDesk_CPU/
Project Hot Box
Oppbevaring
Yes they are identical boards. And you are right... that cpu no longer seems to be on the supported list...
How likely is it that asus is shipping with 1000 series disabled to make room for 5000 series?
As mentioned her cpu boots my board no issues, but I never flashed to 5000 series bios and my mobo is 2,3 years old at this point.
Guess I'm plugging my 3900x in here to see if I can flashback bios.
Pretty high. It's not that their disabled, 570 just doesn't make sense with 1xxx when there's so many other budget options for an "old" CPU
https://wccftech.com/amd-confirms-ryzen-4000-zen-3-cpu-compatibility-x570-b550-chipset-motherboards/
Project Hot Box
Oppbevaring
Well I'm throughly confused. I put my 3900x in hers and now it will stay on, it no longer turns off immediately. But it has no display out. Tried a different pci on her gpu and with mine...
How can her cpu not work in hers, but work in mine.
And how can my cpu only half work in hers? I feel like I answered my question... motherboard?
Clear CMOS on her board just in case BIOS got angry with the 1600.
Project Hot Box
Oppbevaring
I was really hoping this would be the first time cmos solved my problem. No dice. This gpu is going through a cheap dp to hdmi adapter. No hdmi on it, lol radeon. That's the last thing I can think of troubleshooting. I'm grasping at straws now.
Can you try HDMI to HDMI to eliminate the adapter? Dp to HDMI should be fine though.
Project Hot Box
Oppbevaring
1 hour ago, DSTECH said:
X570 boards dont support ryzen 1xxx series only ryzen 2xxx series and later.
1600 wont work at least 2200g or later required.
** Some x570 boards support 1600 AF cpu only not 1600 non af.**
Many boards work fine with 1000 series, despite not being officially supported, and as he already stated the 1600 works in his identical X570 board.
I'm not really sure i get your point. Again, that list details official compatibility. And in much the same way that chart suggests A320 boards dont work with 3000 series, when in many cases they do, its also the case that many X570 boards will work just fine with 1000 series.
As evidenced by the fact that the OP has the 1600 running just fine in his non-faulty X570 board.
Its mostly about the AGESA code included in the BIOS having the appropriate microcode for all the different CPU models. Some boards have space issues and dont include everything. Many X570 boards however do include the microcode for all Ryzen CPU's.
  • 3 weeks later...
Figured I'd give closure to this. Bought another motherboard, didn't work. Pulled every part out of hers, plugged them into mine one by one. Sent the motherboard back bought a 3rd one. Computer now works great. I don't think iv ever had a seamless new build Haha.
Oh and just to reiterate, all of the ryzen 1000 series iirc, certainly the 1600 was once listed on that supported cpu list or I wouldn't have chosen this board for a upgrade path. It's odd it no longer is. I think I got 3 different boards with different agesa codes. One turned off immediately, one turned on with no display out, the last finally worked no issues at all.
