So I recently started to run out of space on both my C and D drives, and in the process of deleting unused programs, I noticed a lot of files that seemed like junk (temp files, program installers, etc.) taking up a good amount of space. I was wondering what your best tips to deal with junk in on your pc, or any free software you would recommend. I can't find any good ones as they all seem to have mixed reviews especially in terms of background usage.
https://linustechtips.com/topic/1300562-pc-cleaning-tipssoftware/
ccleaner is what ive always used.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
I've been using CCleaner for the past 12 years and it's never really let me down. Paired with the stock Windows disk cleanup tool for some of the odds and ends it doesn't catch, it's been perfect.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
Sounds like CCleaner may be the best option then! Thanks for the suggestion!
Just now, Electric_Spark said:
Yeah that doesn't sound like a lot of fun 😆
yea but it's one of the cleanest ways to go about it, rids of all junk file you dont need (or more specifically, you only put what you need back in)
-sigh- feeling like I'm being too negative lately
Windows has a Disk Cleaner inbuilt. Go to "My Computer/This PC" and rightclick C:\ and select "Properties" and the Disk Cleanup is on the First TAB (General)
It's also worth going into C:\Users\ProfileName\Appdata\Temp and emptying that folder (some files may be in use, skip those)
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
