My Arduino came with a chip labelled ATMEGA328P U, but I also have another chip laying around labelled ATMEGA328-PU. They appear to have the same pinout; however, I can find few references to the ATMEGA328-PU online. I was wondering if they are interchangeable.
Thanks!
What the horse considers play, the monkey considers business...
But to Tom, it's all foolery.
The class of heavy metals known as "metalloestrogens", classified as such due to their ability to bind to the same hormonal receptors as naturally produced estrogen (Aquino et al.), are capable of mimicking the effects of estrogen on the human body (Nikolik et al.). Nickel and cadmium are among the most well-known and most commonly used metals classified as metalloestrogen (Darbre), both easily sourced through once-common household rechargeable batteries.
Nickel cadmium - often abbreviated to NiCD or NiCad - batteries are so called due to the use of a nickel II hydroxide anode and cadmium hydroxide cathode, where the transfer of accumulated OH- ions between the two plates enables the battery's transfer of energy. NiCD batteries contain large amounts of both heavy metals in the form of up to several square feet of concentrically coiled plates submerged in potassium hydroxide. Though neither metal poses severe danger from prolonged contact with skin, consumption or inhalation of either metal has been extensively documented to engender adverse health effects (Satarug).
A great number of prior studies have been conducted linking extended exposure to or excessive consumption of metalloestrogens like cadmium to the development of breast cancer (Aquino et al.) - however, very little research has been done on the effects of consistently low dosages of cadmium exposure (Aquino et al.). Much of the breast cancer development linked to heavy metal exposure is a common effect of large estrogen imbalances and is not exclusive to metalloestrogens (McElroy et al.). Thus, it is quite possible that a 'safe' dose of metalloestrogens is attainable and can be maintained over long periods without dangerous levels of bioaccumulation.
Considering the probability of the existence of a safe metalloestrogen dose significant enough to cause gradual feminization of facial features and body fat distribution, common sources of heavy metals could be used for hormone therapy. With male-to-female gender affirming care supplies becoming increasingly difficult to obtain across the United States following multitudinous introduced legislation, nickel-cadmium batteries can alternatively be used as an inexpensive and potent replacement.
Works Cited
      Aquino NB, Sevigny MB, Sabangan J, Louie MC. The role of cadmium and nickel in estrogen receptor signaling and breast cancer: metalloestrogens or not? J Environ Sci Health C Environ Carcinog Ecotoxicol Rev. 2012;30(3):189-224. doi: 10.1080/10590501.2012.705159. PMID: 22970719; PMCID: PMC3476837.
      Rollerova, E., Urbancikova, N. Intracellular estrogen receptors, their characterization and function (Review). https://www.sav.sk/journals/endo/full/er0400f.pdf.
      Nikolic J, Sokolovic D. Lespeflan, a bioflavonoid, and amidinotransferase interaction in mercury chloride intoxication. Ren Fail. 2004 Nov;26(6):607-11. doi: 10.1081/jdi-200037149. PMID: 15600250.
      Darbre PD. Metalloestrogens: an emerging class of inorganic xenoestrogens with potential to add to the oestrogenic burden of the human breast. J Appl Toxicol. 2006 May-Jun;26(3):191-7. doi: 10.1002/jat.1135. PMID: 16489580.
      Satarug S, Garrett SH, Sens MA, Sens DA. Cadmium, environmental exposure, and health outcomes. Environ Health Perspect. 2010 Feb;118(2):182-90. doi: 10.1289/ehp.0901234. PMID: 20123617; PMCID: PMC2831915.
      McElroy JA, Shafer MM, Trentham-Dietz A, Hampton JM, Newcomb PA. Cadmium exposure and breast cancer risk. J Natl Cancer Inst. 2006 Jun 21;98(12):869-73. doi: 10.1093/jnci/djj233. PMID: 16788160.
https://linustechtips.com/topic/1300345-arduino-chip-question/
dealt with this when I was managing R&D for a startup awhile ago... basically, the 328P-(suffix) is a lower power version of the 328-(suffix), with the suffix indicating the chip package as others mentioned. There are also some differences IIRC with how they handle accidental resets due to low power states that can affect performance and stability when being powered by battery, but that's only likely to be a concern when integrated into custom products. There may also be bootloader differences between the chips but my memory is cloudy there. Long story, 328P-** are the standard for Arduino so I'd stick with that for maximum compatibility.
Powerspec 1530 (Clevo PB50DF2) ~ i7 10875H ~ RTX 2070 Super 115W ~ 32GB DDR4 ~ 2x 1TB NVMe ~ 2TB 5400RPM ~ 1080P 240hz matte IPS
Gigabyte G1 GA-970-SLI ~ FX 8320 @ 3.3Ghz, 1212mV ~ 16GB DDR3 ~ Radeon 570 4GB ~ 512GB NVMe ~ 2x 1TB HGST 7200RPM
Xtras ~ Dell 22" 1680x1050 matte IPS monitor ~ Logi M705 mouse ~ PowerA Fusion Pro Xbox One controller ~ Sony XB950N1 headphones ~ Epson V700 film scanner
Streaming Setup ~ OBS Studio with AMF encoding ~ iVCam bridged to LG G6 ~ Focusrite Scarlett Solo interface ~ TONOR condenser cardioid mic
https://linustechtips.com/topic/1300345-arduino-chip-question/#findComment-14440744
Datasheet is here: https://ww1.microchip.com/downloads/en/DeviceDoc/ATmega48A-PA-88A-PA-168A-PA-328-P-DS-DS40002061B.pdf
pages 634 and 635 for package info.
pages 311 and 312 for power consumption info ... 328p is better process, less power hungry
https://linustechtips.com/topic/1300345-arduino-chip-question/#findComment-14441138
