Issues with titanfall screen tearing and not very smooth video
drewtcjones
with vsync on i get non smooth video
with it on i have tears
i5-4670k, Asus VI Hero, Corsair Vengeance Pro Series Red 8GB (2x4GB) @1866 MHZ, EVGA GEFORCE 780 FTW w/ACX Cooler, Fractal Define R4 Windowed (Black-Pearl), Samsung Evo 250GB, WD 1tb Blue, EVGA SuperNOVA NEX 650, Acer H236HL 23" x2, Corsair H100i, 2x Noctua NF-S12A, 2x Noctua NF-A14, Steelseries Apex, Logitech G602
Is your monitor 60Hz? Only thing to eliminate the screen tearing is use vsync.
I have the same issue btw, it's tearing only in the middle of the screen. I just deal with it because I refuse to use vsync.
yupp it's 60hz
Try using the frame rate limiter in RivaTuner that comes with your OC software for your graphics card; set it to 60.
okay I'll try that thanks
Whats your FPS?
Titanfall`s framerate is based on your monitors refresh rate. In this case he would be getting 60.
That's if his system is running perfect..Which is why i asked I mean what if he was getting 30FPS?Then we would know something is wrong elsewhere.. :D
this has been confusing me, I turned off vsync in Titanfalls options and fraps began to read 126+, but I thought it was supposed to be locked at 60
nope fraps with vsync on 60 it off 126+
I sure hope he`s not getting 30fps with a 780. I see what you`re saying though. :P
Are you using the in game Vsync or Nvidias?
My framerate is locked at 60 with vsync off in Nvidia Control Panel as well as in the game.
ive messed with both but no avail
really? i have it off in the control panel and have it off in game and i get readings of 126+
CORRECTION: I have it turned ON in game and my readings get above 60
HEY TRY THIS (sorry caps) but you have to have vsync on in game
Having vsync enabled in the control panel and in game? Wouldn't that just turn vsync on?
Now that I'm looking at your settings, you should set multi-display to single display only and power management to maximum performance.
i was confused by it but it worked for me
I'll give it a shot
Hmm that didn't seem to do anything; I was still locked at 60fps. I think that'll be fixed in an upcoming patch, but it still won't fix the tearing. It will utilize SLI and give use boner inducing framerates at least.
that sucks... i still really enjoy the game even if it has a few tears here and there but damn they are annoying
The way to get above 60 fps is to turn v-sync on in game & force it off in nvidia control panel.
Doing this got me up to 144 fps in the beta but didn't fix the stuttering that seemed to be related to mouse movement. Not even gsync smoothed out the stutter so I'm just waiting til they get everything ironed out & picking this up on sale.
CPU - 3770k @ 4.7GHz | Motherboard - Asrock Z77 Extreme4 | RAM - Crucial Ballistix Sport 16GB @ 1600 | GPU - EVGA GTX 770 SC ACX (2x SLI) | Case - Coolermaster HAF XM | Cooling - CM EVO 212 | Storage - Corsair Force 3 90GB | WD 2TB x 2 | PSU - Thermaltake SMART 850W | Display - Asus VG248QE 144hz + GSYNC kit |  Mouse - R.A.T. 7 | Sound - Creative Titanium X-FI HD | DT990 | ATH-M50 | ATH-AD700
the game is locked at 60 whit vsync off and it has mouse sensitivity issues because its synced whit the framerate but according to respawn, it would be fixed in the first client patch
this is one of the greatest thing that has happened to me recently, and it happened on this forum, those involved have my eternal gratitude http://linustechtips.com/main/topic/198850-update-alex-got-his-moto-g2-lets-get-a-moto-g-for-alexgoeshigh-unofficial/ :')
i use to have the second best link in the world here, but it died ;_; its a 404 now but it will always be here
That worked but I was getting stuttering too. I think I'll just stick to the locked framerate.
