How do I get a right-angle adapter for this USB 3.2 Gen 2 thing?
Solved by flibberdipper,
Just now, DankDoodles said:
There aren't anything from newegg, amazon, or bestbuy? even b&h?
Not that I could find. The literal only other option I could find would require owning an ASRock board and then hitting their support up for a dongle.
Though at the very least, at least MODIY is a well-known company for people like me who find themselves needing a good amount of niche things. Though looking at the page again, I will give the helpful reminder to be sure you order the right version of the adapter, as you could very easily goof that up.
