Using OV7675 Camera module (with arduino) without Arducam shield.
Solved by AbydosOne,
6 minutes ago, Toyota AE86 said:Hi
Some time ago I bought one of the OV7675 camera modules, and I was not able to find any tutorials showing how to use it except ones that involved using Arducam shield. My question is, is there any other way to connect this module to arduino directly, without using shields, and where could I find tutorials how to use those?
Thank You for all answers
I think the shield does the actual capture and processing (there's a microSD slot on it), and the Arduino is only for control and management. An Arduino isn't powerful enough to do more than very rudimentary image I/O.
