Hello,
I recently built a new computer here are the specs
CPU: Ryzen 5600x
GPU: RTX 3070
RAM: corsair DDR4 3200mhz ram
PSU: CORSAIR TX-M Series TX750M
MOBO: Asus Prime B550M-A
So I started building this computer in December,  I started swapping out parts in my old computer as I got new ones. I first got my CPU and MOBO and that was when I started getting the error.  Everything worked well for a couple of days, but I first got the error while watching Netflix through chrome. My computer just restarts, it happens when I use Netflix and Hulu through chrome, Modern Warfare, and I just got apex and its doing it in that. I have reinstalled windows, followed this forum https://docs.microsoft.com/en-us/windows/client-management/troubleshoot-event-id-41-restart. I get all 0's for my bug checker.   I think it has to be my motherboard or my CPU since those were the only things I swapped out when it first started happening. can someone help please :'(.
https://linustechtips.com/topic/1298506-kernal-power-event-41/
1 minute ago, BiotechBen said:
did you already sell off the old components? if not try swapping them in and seeing if the errors still occur to attempt to isolate the problem component.
Yeah I've swapped everything out except the power supply. It was an intel system so I can't test the mobo or the CPU individually. But when it first stated crashing I was using the old PSU so I don't think it can be that.
https://linustechtips.com/topic/1298506-kernal-power-event-41/#findComment-14425613
Kernal power event 41 usually points toward unstable power delivery. it usually means that at some point the power supply was not able to supply sufficient or correct amounts of power and that causes the system to power down unexpectedly. https://blog.pcrisk.com/windows/12891-how-to-fix-kernel-power-error
https://linustechtips.com/topic/1298506-kernal-power-event-41/#findComment-14425628
I tried all of that except updating my bios because I don't have a flash drive rn. Unless there is another way of updating it.
https://linustechtips.com/topic/1298506-kernal-power-event-41/#findComment-14425648
IIRC kernel power event 41 does not really mean anything apart from the fact that OS was not shutdown properly. So it basically means something is causing hard reset. Can be anything... knowing AMD and their software first thing I'd do is updating bios.
Might be a good idea to play around with bios settings too, like disabling XMP and CPU boost, just for troubleshooting purposes...
https://linustechtips.com/topic/1298506-kernal-power-event-41/#findComment-14425653
yeah, if XMP is running, turn it off. it sometimes does strange things.
https://linustechtips.com/topic/1298506-kernal-power-event-41/#findComment-14425654
Ya I turned D.O.C.P off which I think is XMP? its still crashing and I tried to lower my ram timings to 2800MHz and that didn't help. I also underclocked my CPU and that didn't work 😞
https://linustechtips.com/topic/1298506-kernal-power-event-41/#findComment-14428680
