For what? Gaming and general use? Literally no difference between a regular old sata mx500 drive or the best pcie 4.0 one. Maybe in the future we'll see them being used a bit more but right now totally beyond pointless. If you really want a nvme drive with a bit better performance than sata but high capacity get like a sx8200 or something
https://linustechtips.com/topic/1298252-980-pro-worth-it/#findComment-14423552
No.
I mean, that's not entirely true. You can see small gains with NVME vs SATA. They're just not huge. The SX8200 is no longer a great drive to recommend.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/1298252-980-pro-worth-it/#findComment-14423570
Gaming and general use.. maybe video editing in the future
And if I copy files and install things on the drive.. the gen4 do that faster?
https://linustechtips.com/topic/1298252-980-pro-worth-it/#findComment-14423580
Sort off. Most installers are single threaded so they run into a single core cpu limit which can already happen on old sata ssd drives. Copying is always dependent on the slowest drive. So unless you have 2 equally fast ones or the drive you are copying to and from is faster you'll never reach full speed.
https://linustechtips.com/topic/1298252-980-pro-worth-it/#findComment-14423586
If premium PCs mean not sensible in ways that makes you feel better, then PCIe 4.0 drives are worth it.
Desktop benching:
https://linustechtips.com/topic/1298252-980-pro-worth-it/#findComment-14423610
Yeah because of that I think that this drive not matter so much... so maybe it isnt worth it?
If I will buy good gen 3 drive with this.. this speeds are limited so much?
https://linustechtips.com/topic/1298252-980-pro-worth-it/#findComment-14423868
Really in the end the speed doesn't really matter as the only actual reason you'd ever need those speeds is if you:
1. Need a lot of virtual memory
2. A very very very fast scratchdisk (like for video editing massive files so projects of at least a couple hundred gigs, 3d render data,...)
Other than that it's pointless.
https://linustechtips.com/topic/1298252-980-pro-worth-it/#findComment-14424458
So if it is expensive build.. it is not good for futureproof maybe and not copy files more faster?
maybe I will do video editing in the future..
https://linustechtips.com/topic/1298252-980-pro-worth-it/#findComment-14424496
File copying is always limited to the slowest drive. So it's pointless if the other drive you have is slower. Don't futureproof that is bs anyways. Just get a good drive and if stuff changes in the future upgrade. We don't know what will happen the consoles using ssds may change a lot or it may just be that people that are running a generic sata ssd will load stuff maybe a second or 2 slower than people with the fastest most expensive drive there is and basically wasted a heap of money.
https://linustechtips.com/topic/1298252-980-pro-worth-it/#findComment-14424507
It's a great drive, depends how heavy use you are and what workflow. This gen the Pro variant is cheaper than in general. So depends on you.
| CPU: Ryzen 7 7800X3D | MOBO: AM5 B650 Aorus Elite AX | RAM: G.Skill Trident Z5 Neo RGB DDR5 32GB 6000MHz C30 | GPU: Sapphire PULSE Radeon RX 7900 XTX | SSD: Samsung 9100 PRO 1TB with heatsink | Cooler: Arctic Liquid Freezer II 360 | PSU: Seasonic Focus GX-850 | Case: Lian Li Lanccool III | Mousepad: Zowie GTF-X  / Vaxee PC / PA / Artisan Raiden Mid XXL| Mouse: Vaxee XE wired / Hitscan Hyperlight | Keyboard: Wooting 80HE zinc alloy raw - geon raw HE switches | Headset: Beyerdynamic MMX 300 (2nd Gen) | Monitor: LG 32GS95UV-B OLED 4K 240Hz / 1080p 480Hz dual-mode | OS: Windows 11 |
https://linustechtips.com/topic/1298252-980-pro-worth-it/#findComment-14426466
17 minutes ago, Zowy1 said:
But it is limited to the slow drive if I copy files..
Well yeah, that's a copy. If you work on the faster main drive, that's the idea for it's use.
https://linustechtips.com/topic/1298252-980-pro-worth-it/#findComment-14426690
37 minutes ago, Zowy1 said:
You give me examples where I notice the difference versus good gen3 drive?
Any workload that can use high throughput like work with video, export, and such. Unless you copy hundreds of GBs every day and do said workflows you may not need it.
https://linustechtips.com/topic/1298252-980-pro-worth-it/#findComment-14426852
Maybe video in the future video editing and I want that because of the 5900X
have a chance that in the future the 980 pro Will be better utilized? and I see have 100$ difference between good 1TB NVME and 980 PRO 1TB
https://linustechtips.com/topic/1298252-980-pro-worth-it/#findComment-14426888
Yeah I guess best to buy what you will use now, can always upgrade in the future. You should check 980 Pro reviews and other competitors and decide what fits you.
https://linustechtips.com/topic/1298252-980-pro-worth-it/#findComment-14426897
Some people told it is better to wait for the 2TB version..
I dont know if its more profitable to me right now - buy this or buy 2TB gen3 drive and wait until the 980 pro was dropped or discounted more
https://linustechtips.com/topic/1298252-980-pro-worth-it/#findComment-14426908
Right, that's all on your though, how much capacity/speed you need and do you need it soon.
https://linustechtips.com/topic/1298252-980-pro-worth-it/#findComment-14426935
It's possible it's probably just out. It's on some etailer stores too for pre-order.
https://www.samsung.com/us/computing/memory-storage/solid-state-drives/980-pro-pcie-4-0-nvme-ssd-2tb-mz-v8p2t0b-am/
https://linustechtips.com/topic/1298252-980-pro-worth-it/#findComment-14426996
